Old 01-15-2013, 12:30 PM   #21 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
they are 10% brighter than other bulbs at the same wattage
Great, we can run them 2-3% under-voltaged for longer life!
Old 01-15-2013, 12:32 PM   #22 (permalink)
Ill say this, I have them in my high beams on my insight. I drive or drove 18 miles through a rural area with them on for like 30 minutes or so a day. With regular halogen the cabin of the car would get toasty warm and I would turn down or off the heater. With the eco bulbs this did not happen and they seemed maybe 10% less bright. The IMA system which includes the DC to DC converter which replaces a alternator in a hybrid vents into the cabin of the car.
Like mentioned, for ultimately brightness and energy savings go hid, get the smallest ballasts like 35 watts, get a white bulb like 4300k and get the relay kit to avoid any electrical problems. Just be ware these do not work if your high beam is used as a DRL.
Old 01-15-2013, 12:36 PM   #23 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
1.lums are 2800 for a D2S 4300k low beam bulb.
lum are in thousands.
the ad says 200-300 so it's a fog bulb.
2. It's square so it's not REALLY 360.
3. Multiple bulbs WILL NOT throw the light farther. which is the entire purpose of headlamps.
here is a thread I wrote on HID's (plug n play) failing in halogen lamps.
The same reasons exist for the leds failing in a halogen lamp
HID plug n play fails govt test
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
christofoo (01-15-2013)
Old 01-15-2013, 12:42 PM   #24 (permalink)
mcrews's Avatar
Originally Posted by Cobb View Post
Ill .
This is inccorrect (FACTUALLY).
An HID bulb mounted in a lamp designed for a HALOGEN bulb doest not work correctly.
PLEASE show a picture of your hid bulb on shining on a wall. Park 30 feet away.
IT FAILS. PERIOD.
Please read the thread I posted from HIDPLANET.
ECO MODS PERFORMED:
First: ScangaugeII
Cobb (01-16-2013)
Old 01-15-2013, 01:39 PM   #25 (permalink)
christofoo's Avatar
00C - '00 Toyota Corolla
90 day: 43.54 mpg (US)
I think the EM Wiki needs to be updated on LEDs (ref post #10).
1. Differentiate halogen head-lamps vs parking/tail-lights.
2. Explain geometry problem with swapping halogen low-beams.
3. Define motivation for power reduction.
4. Include HID discussion.
5. Remove obfuscating references.
Now... back to 'eco' halogens? (End thread-jack?) They reduce power in the low-beam setting, but not a ton, 20W total in my test, and unlike LEDs and HIDs they are halogens with the proper geometry so the low beam pattern meets DOT approval (and is socially responsible).
Old 01-15-2013, 01:52 PM   #26 (permalink)
christofoo's Avatar
Originally Posted by christofoo View Post
Assuming 37kWhr/gal for gasoline: (EDITED)
'Eco' bulbs: reduction of 20W/15%(efficiency)/37,000Whr/gal = 0.015 gal/hr
HID (hypothetically): reduction of 0.03 gal/hr
So if you hypothesize that 'eco' halogens costs you $5 for one reason or another, the ROI is:
$5/(0.015gal/hr*$3.6/gal) = 90 hours of low-beam operation
Which is almost certainly within the lifetime of the bulb. (Or make it 200-300 hours if you throw away your old bulbs to put in new ones.)
So purely in economic terms, this type of bulb is probably worth using, even if you have no special purpose like an alt-delete or extensive after-dark engine-off time.
But clearly if there is no special purpose, this mod is about pinching pennies and splitting hairs. Although the electrical draw is easily measured, I'd expect the effect on fuel to be lost in the noise.
The Following User Says Thank You to christofoo For This Useful Post:
justme1969 (01-15-2013)
Old 01-15-2013, 02:07 PM   #27 (permalink)
It is 33.7kWh per gallon of (E10?) gasoline.
Old 01-15-2013, 03:08 PM   #28 (permalink)
christofoo's Avatar
Yes, I believe so. Sorry.
Old 01-15-2013, 03:10 PM   #29 (permalink)
justme1969's Avatar
I think this was great info overall but we jumped far off topic so Ill try to close my point with this lower voltage option that Im believing will work for my purpose.
The fact is the LED headlight still is a myth because of intensity, range, and color issues;
DOT here in USA has not approved them.
"angel eyes and others are more ambiance and dont effect night visabillity much."
The ones listed are infacto driving lamps, and fog lights.
They will work well for my purpose, and will be usefull for keeping alternator calm and quiet mostly.
here is a maxxima catalogue
http://maxxima.com/downloads/2012MaxximaCatalog.pdf
Old 01-16-2013, 03:44 AM   #30 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Top post! cant believe this has stimulated so much debat, but it is good to see
So you could expect to see an investmetn return within the lifetime of the bulb when using it as a dipped beam only?
Currently I'm running dipped beam to/from work 5 days a week on a 2hr return trip, making the payback period (in hrs operation) as 9 weeks (say 2 months)- so this could save me approx 1 impg Gallon over 9 weeks?
If so, I'm currently getting 25mpg on LPG, a 1 imp gallon reduction over 9 weeks would take me from 25 up to 25.21mpg..
worth it?
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
