Old 02-02-2023, 07:33 PM   #81 (permalink)
90 day: 39.89 mpg (US)
Work Vehicle - '17 Toyota RAV4
90 day: 33.96 mpg (US)
What do you mean by less aggressive? How would you expect it to affect towing capacity?
The current tires are 10mm wider than stock, and are a sticky ultra high performance summer compound - they're goopy enough that rocks and pebbles just stick into the tire, not just between tread blocks. I was thinking of dialing them back to the stock width, and maybe back to "high performance summer". They still have a lot of life left, however.
As for towing... probably not much? I was towing much heavier loads in the Insight, with 165 width RE92s.
Old 02-03-2023, 12:25 AM   #82 (permalink)
mpg_numbers_guy's Avatar
Raven - '13 Toyota Prius C
I have a few very small mods planned for it in the immediate future: LED turn signals, DVD player delete, a partial grille block, and when I do eventually need tires, something a little less aggressive.
How are NZ regulations for vehicle modifications?
2013 Toyota Prius C (my car) 60 MPG
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car) 40 MPG
Old 02-03-2023, 01:00 AM   #83 (permalink)
They're very explicit.
https://www.lvvta.org.nz/documents/s..._Threshold.pdf
For example:
Fitting of or modification to: LVV Certification is not required provided that: (refer to LVV Certifier if beyond threshold below):
Body kits and components (including utility canopies, plastic bumper skins and bonnet projections)
▪ the fitting system does not weaken the vehicle structure (Note 1); and
▪ no frontal impact components have been removed where the vehicle is required to comply with a frontal impact occupant protection standard (Note 3); and
▪ the kit or components do not present any forward-facing external projections that could cause injury, to the occupants or pedestrians, or present a snagging/hooking risk to a vehicle or person; and
▪ the driver’s vision has not been affected; and
▪ the performance of any lamp is not affected as a result of the kit or components.
Basically, they're strict on safety, and lax (or don't care at all) about emissions or power.
A vehicle needs no certification as long as it meets those standards. A one-time certification is needed if you exceed them, where a mechanic inspects it. I can, for instance, do lightweight 2 piece brake rotors without certification, but if I change the calipers for aftermarket, I need them certified - but if they're meant for the vehicle, they'll almost certainly pass.
Old 02-04-2023, 12:58 AM   #84 (permalink)
Weight capacity of the tires is just one aspect. I was wondering how a different tire would affect traction.
