Old 10-26-2016, 04:56 PM   #91 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
Also added more rustproofing for the winter (Found out the body is galvanized- YES)
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
Old 10-26-2016, 05:10 PM   #92 (permalink)
Fingie's Avatar
The new Vesta will be out 2017. If it hits big i'll buy one at least in 2025.
Only announced 33MPG? Well, I guess it's Russian-spec.
Old 10-26-2016, 05:13 PM   #93 (permalink)
Fingie's Avatar
I have an another option for the future...
Old 10-28-2016, 04:40 PM   #94 (permalink)
Fingie's Avatar
buut the war wagon will carry on for a long time.
I am poor AF.
We got the seasonal speed limits (Max 80km/h on all roads, except motorways 100km/h)
Now I can drive 80km/h so my consumption drops. Gotta block the grille and use my DEFA block heater.
Also found out my car's final drive ratio is 4.10.
Old 10-29-2016, 04:40 AM   #95 (permalink)
Renee - '92 Renault 50 Series
90 day: 21.21 mpg (US)
EscortEstate - '97 Ford Escort mk6 ANL
90 day: 37.66 mpg (US)
I find almost everybody around Göteborg just drives the same summer or winter. Speed 'limits' are more suggested sppeds so most drive 20 km / h faster.
For the grill I found some corrogated plastic and have made several grill blocks, with each block having a slightly different sized holes. Then as the temperatures change I can swap the grills.
My plan (if I every get round to it) is to have a complete block with several adjustable vents that I can manually open.
Has the Vaz got an under engine cover ? - I bought an aftermarket one and I have found that its helps a little with economy, but it keeps the engine soooo much cleaner.
Old 10-30-2016, 10:27 AM   #96 (permalink)
Fingie's Avatar
I was on a Swedish band's concert yesterday, a lot of highway driving @ 50mph for a couple hundred miles.
50MPG :O best so far.
Old 10-30-2016, 12:00 PM   #97 (permalink)
Fingie's Avatar
The band was Kent my friend was absolutely delighted as he doesn't have a license.
Old 11-01-2016, 05:27 PM   #98 (permalink)
Fingie's Avatar
It's oil change season soon.
I wonder what I should put in the engine (We have cold winters here)
10w-40
5w30 C2
10W60
5w40 C3
Something else for lower FE
In mind, the engine design is from the 70's with solid tappets/buckets. And EURO 3 emissions.
The gearbox accepts anything API GL-4 (GL-5 is too slippery for the syncros and corrodes the copper in the syncros)
or should I try ATF in the gearbox? Will the diff complain?
Now I have GL-4 Mineral in the box.
when VAZ released the Samara (Same gearbox) they just recommended standard motor 10w-40 oil for the gearbox so it's not very picky .
Old 11-01-2016, 11:13 PM   #99 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
Cold winters usually mean thinner oil, I would guess that if you spend much time below -10C, a 5W-30 should do fine... It's my experience however that older designed engines aren't quite as picky on oil viscosity as the newer designs are...
My current Ecotec project...
My last Ecotec project...
Old 11-02-2016, 03:55 AM   #100 (permalink)
How far has the car gone ?
My previous car had gone a fair distance and the thinner oils would disappear, nothing excessive but between oil changes it'd prob take an extra 1.5 l.
Here is a site with a little information about oil viscosities but as bonestock said the 5W30 should do fine.
Car Bibles : The Engine Oil Bible
Judging from your list of oil it looks very much like the biltema oils, and I have used found them to be quite alright, although now I buy oil over the internet, where I can get a premium oil with postage for about the same price as a lower midrange oil in the shops.
Opie Oils - Automotive Fluids, Oils, Parts, Tools is the company I used last (and will use again), their prices are about the best, they will actually post abroad and they have a wide range of filters and oils. Delivery was awful though as it went with UPS and I ended up having to go to their terminal (40km away) to pick it up.
Haven't really listened to much of Kent's music, shame that they are finishing though.
The Following User Says Thank You to MJamson For This Useful Post:
Fingie (11-02-2016)
