Old 07-22-2012, 10:33 PM   #11 (permalink)
ERTW's Avatar
Bu - '08 Chevrolet Malibu LS
90 day: 32.29 mpg (US)
I have the alpine imprint - which is supposed to set frequency response and delay automatically. Nobody has the mic where did you get that mic? I doubt best buy will take the time to set it well.
I'll see if my 6x9s will give me enough bass. Thx for the idea
Old 07-23-2012, 04:55 PM   #12 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I have a question!
I installed some new speakers in my car and I attached them to the plastic(?) door panel rather than the stock mounting bracket in the car. I'm fairly pleased with the result, but my question is this: will the low-end response be better if it's attached to the frame rather than to do the plastic door panel, even though the front and rear of the speaker won't be isolated from each other?
Old 07-23-2012, 07:18 PM   #13 (permalink)
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
Depends. play something low end heavy and feel the door panel. flexing much? the more solid it is, the more low end is being transmitted. flexing even the thickness of your fingernail can have a significant impact on your overall low end efficiency!
With my doors, i mounted them to the metal, such as factory speakers would. then, i used chloroplast and foil duct tape to seal the door. then, i taped a layer of foil bubble insulation. finally, the door panel itself. though, the steel door skin flexes more than i would like... some angled aluminum riveted would help.
Old 07-24-2012, 01:39 AM   #14 (permalink)
I can feel it vibrating but there's no visible flex even with heavy bass. It's not terribly sturdy, just ~1/8" plastic with some foam and vinyl over it.
What did you use to cut your MDF? I'm without access to a bandsaw and cutting it by hand doesn't sound appealing.
Old 07-24-2012, 10:07 AM   #15 (permalink)
F Truck - '77 Ford F100 2x4, single cab, lwb
90 day: 8.75 mpg (US)
Bombodore - '98 Holden Commodore Exec Wagon
90 day: 21.35 mpg (US)
Civic - '93 Honda Civic GL
90 day: 36.62 mpg (US)
Jim The Prius - '09 Toyota Prius
90 day: 36.66 mpg (US)
im also a big lover of car audio, so much so that i opened a shop to share my love with customers lol
my car previous car had similar goals but i held sound quality and price over weight
Alpine CDA9887 head unit, 16wrms x4, active crossovers and time alignment.
Tang band W4-1320SJF wide band 4" in fibreglass dash pods. (would have used the neo versions if weight was a priority over price)
Peerless HDS 8" mid/sub bass in MDF floor pods. (again would have used neo woofers and fiberglass pods if weight was a priority over price)
the 4"s were high passed at 300hz 12db/oct and the 8"s low passed at 300hz again at 12db/oct.
played within 3db down to 30hz and over 110 db at full noise.
the floor pods were built as putting the 8"s or dual 6.5" in the doors would have weighed more and cost more to get the same low end extension due to the cost and weight of deadening products.
a couple of pics:
(Posted in 2020) 2009 Prius Off Road project: https://ecomodder.com/forum/showthre...ide-38366.html
(Posted in 2012) 1977 F100 Project: http://ecomodder.com/forum/showthrea...tml#post310326
Old 07-24-2012, 10:56 PM   #16 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Originally Posted by bobo333 View Post
That looks like the setup I want for my home theater.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 07-24-2012, 11:09 PM   #17 (permalink)
NoD~'s Avatar
I have never considered full pods on the dash like that... props! Tang-band full range drivers are pretty sweet, especially for the $$! I made a portable kareoke setup for a friend with 4x 3" full range drivers and they sounded phenomenal for their size and price!
Old 07-24-2012, 11:46 PM   #18 (permalink)
wrx4me...
no worries - '91 Subaru legacy L
90 day: 31.45 mpg (US)
weevee - '08 suzuki vstrom dl650
90 day: 61.22 mpg (US)
wrx - '09 Subaru wrx sedan
90 day: 29.8 mpg (US)
Big Bright Green Pleasure Machine - '09 kawasaki ninja 250 se
Connie - '09 kawasaki concours
[QUOTE=NoD~;317002]Thanks, ecomodded. Glad to see other stereo lovers on here.
I actually have a phone dock and can play through it... though, I'm charging my phone with the 12v system by doing that. However, I have eventual plans to change my sunroof into a small ~80w solar array, which should help cover some of the electrical costs.
As an update, I did a 2nd round of tuning. I knew there was room for improvement... I think I got it pretty fine tuned this time.
Awesome job....nice to see someother audio addicts here...never bothered with doing that in my car but one time, i have become more tolerant of bad sound in the car as i get older. Lazy i guess lol
Old 07-25-2012, 01:44 AM   #19 (permalink)
wyatta4's Avatar
CRX:HF - '89 Honda CRX HF
90 day: 53.05 mpg (US)
NameGoesHere - '15 Volkswagen Golf TDI SEL
Frik these are sweet... I hear that most shops can't tune worth a crap.. And I don't have the equipment to do so when I have my system in.. Any suggestions??
Check out my project here---> 1989 CRX HF
Follow me on Twitter. @secsieAzul
Old 07-25-2012, 01:45 AM   #20 (permalink)
wyatta4's Avatar
And what's your photobucket NoD? I wanna check the rest of your stuff out...
