07-23-2014, 09:28 AM
#41 (permalink)
Not banned yet
Blue - '03 Chevy S-10, LS
Originally Posted by Smurf
However, much of this effect can be minimized by not pouring large amounts at once, correct? For a grill block, let's say, you could fill the "deep" part about two inches, let it cure some, then add another layer to build up your depth? Will GreatFoam glue to itself to form a solid piece, or would it break off in the layers?
I think many of us have big ideas for GreatStuff but are intimidated by all these 'rules'
problem is, two inches expands to four to six inches, creates voids if not careful and the wands can only be used once. i've used it but not on a car. if your molds are thin material, it will push and deform it.
i will try two part next myself.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
07-23-2014, 12:17 PM
#42 (permalink)
Cyborg ECU
This soft center problem would be partly solved by reusing polystyrene laying around as a core, no? I have a bunch of such stuff laying around from appliance and parts purchases. A layer of polyurethane "great stuff" under as a base and protection, then the styrene, then surround the styrene with a 1" layer of "great stuff" which will expand to three times its initial volume, create a sandable surface, and protect the styrene core from polyester resin. Saves money and reuses styrene too.
07-23-2014, 01:07 PM
#43 (permalink)
Do more with less
Rather than mess around with spray cans of foam just get the regular two part foam.
LIQUID X-30 FOAM from Aircraft Spruce
I would also suggest a starter kit from the same vendor.
– Noah Webster, 1787
The Following 2 Users Say Thank You to Varn For This Useful Post:
07-23-2014, 09:34 PM
#44 (permalink)
Not banned yet
the X-30 FOAM, 2 GALLON KIT 01-09000 for $198.85 looks like a good deal. sorry about already purchasing the great stuff but i wouldn't mess with it either.
07-23-2014, 10:56 PM
#45 (permalink)
Do more with less
The two gallon kit is enough to make a boat almost.
The Following User Says Thank You to Varn For This Useful Post:
07-25-2014, 02:45 AM
#46 (permalink)
Not banned yet
or for other projects.
