Old 06-27-2008, 10:31 PM   #241 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
ad assume that the car would be pretty long and moving the rear wheel back would help quite a bit for stability and comfort of the ride
Old 06-28-2008, 10:13 AM   #242 (permalink)
ttoyoda's Avatar
I was thinking long as well, but do you think it would matter that the intersection points of the ackerman steering would not line up any more
Ackerman Steering Geometry and Racing
Old 06-28-2008, 08:16 PM   #243 (permalink)
Veggiedynamics
filled up today 383.4 miles and 7.304 gallons of fuel.. 52.49 MPG, that's with 90 miles of 30mph head winds as a storm rolled in.. so basically I was traveling through the wind at 85-90 mph.. I was really having to get into the throttle more than usual to keep at the speed limit.
Old 06-29-2008, 09:14 PM   #244 (permalink)
Veggiedynamics
Updates for this weekend, the rear wheel skitrts are in place.. here are a couple images:
I gave them 1" clearance fromt he tire to allow for diffrent tires later on Im planning on going to the 14" low rolling resistance tires from the insight eventually or a 15" 155r-80-15.
Old 07-03-2008, 03:32 PM   #245 (permalink)
Veggiedynamics
I think im going to put the hood back down to stock, I'm not seeing lots of air flow through the opening and if the wife wants to drive the CRX she doesn't like it..
Old 07-07-2008, 01:20 AM   #246 (permalink)
Veggiedynamics
well , this weekend ahs been pretty uneventful.. besides 4th of july festivities i focused on rebuilding my vegetable oil filtering rig. I run veggie and get a equivilent of about 130 mpg in my 300d benz.. was testing some experimental filtering ideas.. in the end I think i have adapted a great system..
But bac to the CRX.. i took the foam sides off andthe hood extension off the hood in preperation to lower the hood back to stock. I am not seeing lots of air flow from under the hood and feel the stock arrangement will provide the same or better MPG, well see, its not a hard fix to go back to raised.. well see what t does for MPG.
Other than that i painted the rear boat tail and skirts just to see what its looking like.. look more presentable , its just in primer but looks a bit more finished.. its amazing how much people stare now.. my wife and i took a quick trip into town and she was looking at the people stare at the car and point etc.. kind of funny..
Old 07-07-2008, 09:52 PM   #247 (permalink)
90 day: 51.82 mpg (US)
Originally Posted by ebacherville View Post
i wonder if i can get "great stuff" to finance the car, got about 14 cans into the car so far..luckily it was on sale last time i picked it up..
How much foam would you say you get out of a single can of Great Stuff? .5 square foot? .75? I just used an entire can of it doing one side/corner of my Kammback.
Old 07-07-2008, 11:50 PM   #248 (permalink)
Awesome car. From the side it looks like a Nissan Z31
Old 07-08-2008, 07:38 PM   #249 (permalink)
Veggiedynamics
i don't know a square foot minimum .. I was using the crack filler type, the stuff that really expands .. there are kinds for door and windows that don't expand as much..
Old 07-09-2008, 12:45 AM   #250 (permalink)
Do you know about google
Not in absolute volume but...
The theoretical yield of a can of GREAT STUFF is measured in lineal feet of a 3/8”– 1/2” diameter bead. One 12 oz. can of GREAT STUFF has about 250 lineal feet. One 16 oz. can has about 335 feet. One 20 oz. can has about 420 feet. One 6 oz. can yields approximately 120 feet.
HTML Code:
http://greatstuff.dow.com/greatstuff/cons/faq.htm#faq2
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
crx hf help need more info, rear wheel skirts RP-CLMBR Aerodynamics 2 07-16-2008 09:24 PM
Repping the old school Hondas - 85 CRX HF 1GCRXHF Introductions 4 06-16-2008 01:14 PM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 04:14 PM
AFS Trinity EXTREME Hybrids!!! cfg83 General Efficiency Discussion 10 01-18-2008 07:15 PM
