Old 09-27-2024, 12:11 PM   #1611 (permalink)
Primer is still paint!
ChopStix's Avatar
90 day: 32.46 mpg (US)
There’s a lot to ponder in this one!
The Following User Says Thank You to ChopStix For This Useful Post:
Joggernot (09-28-2024)
Old 09-28-2024, 12:14 AM   #1612 (permalink)
Old 10-01-2024, 12:58 PM   #1613 (permalink)
From Just A Car Guy's September banners:
https://justacarguy.blogspot.com/202...s-banners.html
Old 10-03-2024, 12:07 AM   #1614 (permalink)
Once in a while I still see a Karmann-Ghia roaming around.
Old 10-08-2024, 06:28 PM   #1615 (permalink)
Do push-ups.
Old 10-09-2024, 06:20 AM   #1616 (permalink)
Hippie? Idunno. I recall assorted different colors of various flowers and balloons painted on typically a chartreuse base coat. Blue with white upper second, at least in Hermosa Beach
Definitely Goth. Excellent find of a bussie extremely reworked to much better than new
Freebeard would be the authority, with aerohead as the technical back up.
Old 10-09-2024, 12:37 PM   #1617 (permalink)
One might say over restored.
Getting that smooth a reflection in the gloss black would take lot of block sanding down the sides.
Old 10-10-2024, 02:12 AM   #1618 (permalink)
Old 10-10-2024, 09:27 AM   #1619 (permalink)
Probably spline sanding with buffed extrusion. Couldn't do it in metalflake
Door panel edges on that polo are curved result of the crimp process
Old 10-14-2024, 12:08 AM   #1620 (permalink)
Is it a bad thing at all? Just a remind, it's made in India, so I don't know to which extent Volkswagen was aready trying to simplify the manufacturing process there as it does with the new generation.
