Old 03-16-2016, 01:15 PM   #101 (permalink)
Bill the Engineer's Avatar
Would it be easier or more difficult to make a fiberglass plug of the Firebird, and then drop a fiberglass shell on a Prius chassis?
"You are a bad man, destroying a classic like that!"
"This classic--rust bucket? Still there, just cloned it."
It wouldn't be the car that my wife and I dated in that way, (minus the oil smoke, rear wheel hop and rattling over every bump.)
Not concerned about the haters. Like I said before, haters' gonna hate.
Bill the Engineer
The Following User Says Thank You to Bill the Engineer For This Useful Post:
Doc Joe (05-17-2016)
Old 03-16-2016, 01:45 PM   #102 (permalink)
Exactly, it's your car, do what you like. I was thinking when I first saw the pics that the cut down Prius chassis probably had more structural stability than the firebird did when new 😄
Travis..
The Following 2 Users Say Thank You to crashnzuk For This Useful Post:
Bill the Engineer (03-16-2016), mcrews (03-17-2016)
Old 03-16-2016, 02:31 PM   #103 (permalink)
Travis..
That is correct. In fact, the Firebird design was so uncontrollable in its convertible form that Pontiac needed to add harmonic dampers to all four corners of the body to stop body twisting on the highway. They are something like 20lbs each. I still have them, but I doubt that I will need them. Time will tell.
Bill the Engineer
The Following 7 Users Say Thank You to Bill the Engineer For This Useful Post:
bespurcell (04-10-2016), COcyclist (06-09-2017), elhigh (03-18-2016), mcrews (03-17-2016), oldtamiyaphile (03-16-2016), RedDevil (03-17-2016), Xist (03-17-2016)
Old 03-16-2016, 05:43 PM   #104 (permalink)
AeroGuy
eco_generator's Avatar
Outback 14 - '14 Subaru Outback Limited
90 day: 23.1 mpg (US)
Wow, what a different time. Bean counters figured out that adding 80-90 lbs in the furthest corners was the best "fix". Add inertia to every axis of movement, lol. Reduce the car's performance even further to mask a problem with the original modification... Genius!
Old 03-17-2016, 12:52 AM   #105 (permalink)
Okay, but what if you like it so much, you want a second?
mcrews (03-17-2016)
Old 03-17-2016, 01:48 PM   #106 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
... They are something like 20lbs each. I still have them, but I doubt that I will need them. Time will tell...
The Prius frame will be much better, I would think... you probably won't need them... and that is a lot of weight, distributed at corners that will affect it's cornering kinda negatively, no? I guess you'll experiment with removing them, maybe?
Bill the Engineer (03-17-2016)
Old 03-17-2016, 05:16 PM   #107 (permalink)
Already out and in the storage garage.
Bill the Engineer
Old 03-17-2016, 05:18 PM   #108 (permalink)
I will freely share the plans when I'm done.
Old 03-20-2016, 02:11 AM   #109 (permalink)
I bet it would be easier, but anyway if I were going to do a similar project I'd eventually consider a custom-made chassis to avoid some clearance issues.
Old 03-20-2016, 01:55 PM   #110 (permalink)
Cyborg ECU
Awesome generosity. It is one thing to have plans for the projects we have not completed, but a person enters another league when they produce the plans for the unique project they have actually finished! ☺
Bill the Engineer (03-26-2016)
convertible, firebird, firebrid, hybrid
