Old 11-03-2019, 10:10 PM   #31 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
I was not aware to what lengths you would go in pursuit of this goal when I gave my original assessment. I'm still not sure you can do it, but unlike before I'm no longer certain that you won't.
Having lean burn is a huge advantage. That's big.
Is the deep cycle batt so you can remove the alternator for your attempt at the goal?
Old 11-04-2019, 08:26 AM   #32 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Yes, delete alternator hopefully. I think I need to shift my focus for a moment though. I need to get the tank and speedo fixed. If I can't tell what mpg I am getting how do I know if I've made it? I might wire up the deep cycle and not mess with the alternator, just because putting 2 wires in isn't very time consuming.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 11-11-2019, 11:57 AM   #33 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
I attempted to fix the tank this weekend, I couldn't find the exact spot it was leaking. So after 2 attempts I just re-patched it like the PO did. The jb weld is supposed to be good for gasoline so hopefully this fix will last for a few years atleast.
Before:
I don't have a finished picture, but here is an in progress shot just before I put the jb weld on.
I also did a "rough" mpg check before I fixed the leaking tank. I stumbled to the gas station and put 2 gallons in it. I then drove until I ran out again and tracked my mileage by using google maps. It was about 50/50 city and highway and I got ~28 mpg.
EPA ratings:
City 23 mpg
Highway 31 mpg
Combined 26 mpg
Considering I was leaking fuel I think I did pretty good. I got the pinout for the ecu so I should be able to put the mpguino in soon. I haven't finished the tail or the alt delete yet though. I also have a source of 90 octane ethanol free gas, (haven't used it yet though) so hopefully that will raise my mpg some.
1995 Mercury Tracer
Old 11-12-2019, 10:15 AM   #34 (permalink)
Jb weld is Ok, but body filler is better and cheaper for gas tanks.
Old 11-12-2019, 11:29 PM   #35 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
I used the "plastic tank repair" JB weld, it was like $14 though. Are you talking about bondo you could buy at the autoparts store or something more specific?
1995 Mercury Tracer
Old 11-13-2019, 09:18 AM   #36 (permalink)
Common name bondo, yes. Anything like that is lying about in a garage situation that is fuel resistant.
I'm also a fan of red silicon seal and fiberglass sheetrock patches
Old 11-17-2019, 05:40 PM   #37 (permalink)
Dealing with fiberglass for a fuel tank repair, I would be more concerned about the resin. Vynillic resin is better than orthophtalic resin for that matter.
Old 11-17-2019, 09:52 PM   #38 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
I had a busy weekend, installed the deep cycle and wired it up, then unhooked the belt. Put an airdam on, hopefully it helps. I also installed the mpguino that I used to have in the van. I started with the values that gascort had posted on the mpguino wiki. He had the 5 spd though, so I adjusted the vss value until it was close to matching my speed and then filled up the tank. I still need to do some testing to find out what my range is with the single battery. Hopefully next weekend I will have a mpg value for the car!
Any guesses as to what I get with roughly 50/50 city and highway (@55mph)?
1995 Mercury Tracer
Old 11-17-2019, 10:08 PM   #39 (permalink)
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
I think you're effed if you're trying to get 60 MPG at 55 MPH in that thing even with the boat tail unless you go to a really warm climate for the test run and swap in a manual transmission. I guess it could be an excuse for a weekend beach trip.
Old 11-19-2019, 02:48 PM   #40 (permalink)
The Green Hornet - '96 Ford Escort Wagon LX
90 day: 39.26 mpg (US)
The Red Rocket - '96 Geo Metro Base
90 day: 53.07 mpg (US)
I have a 50% underdrive crank pulley for that car, if you are interested. Doesn’t allow alternator to charge at idle but once over 1500rpm it charges. Used it for over 100k miles on my 96 1.9 escort wagon. I picked up almost 3mpg with it. You can see my mpg for it in my signature.
AC, power steering run just fine with it. Drop me a message if you are interested.
