Old 03-17-2011, 10:17 PM   #1 (permalink)
Buggie - '01 Vw Beetle TDI Gls
installed scangaugeII - some questions
when cruising, the engine load% is never below 6%, even with downshifting and using engine braking, is that normal?
The intake air temperature is way too warm, it was at best 15degrees C toady and the gauge showed as high as 40 degrees, crappy intake routing?
Old 03-17-2011, 10:39 PM   #2 (permalink)
Yes, engine load never really hits 0%.
Sounds like you have an OEM warm air intake. Not necessarily a bad thing.
Old 03-18-2011, 05:05 AM   #3 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
It will go to 0 when using DFCO on my diesel car.
(it's around 17-19 @ idle when warm ; up to 40 @ idle when cold)
Does your vehicle have fuel cut off when engine braking ?
The cut-off value can be changed. (manual page 16)
Try increasing the cut-off value a few points and see if the load is reduced to 0 while engine braking.
Old 03-18-2011, 01:42 PM   #4 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
Ambient temps around here are about the same and I've been seeing 100F-115F for intake. I do however have a WAI. I've noticed on my Jeep once she gets past about 110F-120F the GPH drops slightly.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
