Old 01-15-2010, 06:11 PM   #11 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
The reason they made "vents" that weren't is a simple one. They wanted the looks, without making any more air dirty. They didn't need the vents, so they just blocked them from the rear.
Old 01-16-2010, 02:06 PM   #12 (permalink)
Is this the generation of Mazda 6 you have? Seems like you could just cover the space with semi rigid plastic
Old 01-16-2010, 02:30 PM   #13 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
I'm guessing that these are what you're talking about.
In which case, I join the not worth the time to dink with crowd.
Old 01-16-2010, 09:59 PM   #14 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
go to wall mart and get some Duck Tape brand HD Clear tape put it over and see if it gets you the results you want
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 01-17-2010, 03:17 AM   #15 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I'm gonna say do it! If it gets you going and you learn something why not? Agreed that it will make little noticeable difference but it will make a small difference.
Then later tackle the stuff that makes a big difference like the wheels.
Many small changes add up to make a big change.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 01-17-2010, 08:51 AM   #16 (permalink)
Back and Forth - '96 Honda Prelude S
90 day: 30.57 mpg (US)
Thanks for the replies everyone, and yes that is the model/body style of 6 that I have. Ok, if the experts say it's not worth doing for FE, then when I get around to it I'll be doing it for aesthics I guess.
Disregard those numbers for now.
Old 01-18-2010, 06:33 AM   #17 (permalink)
recession proof rebel
k.civic.f4i's Avatar
i say... it cant hurt. if you know how to take your bumper apart it should be easy. i agree with the clear duct tape suggestion or maybe the black duct tape.
at least if you go that route its reversible if you dont like the results. if it were i though, i would probably throw some fiberglass resin or bondo on it, sand smooth(to original contour), primer and paint flat black to maintain the clean stock look(no tape)
how to.....
http://ecomodder.com/forum/showthrea...cks-11998.html
http://ecomodder.com/forum/showthrea...how-12301.html
true wealth comes from good health and wise ways
Old 01-18-2010, 08:44 AM   #18 (permalink)
That would be my prefered method, I just wasn't sure how much weight the resin or bondo might add (I'd probably use the resin). We're talking about a rather small area either way, nothing that'd be noticable to the car overall, but I've always been fond of "adding lightness" to my cars.
Old 01-20-2010, 01:37 AM   #19 (permalink)
Getting BETTER Mileage
Jethro's Avatar
Lucky No 19 - '11 Ram 1500 Express ST
Venti - '13 Ram 2500 Tradesman
You've got the same issues I have. Oversized openings that really serve no purpose.
Currently I have mine covered with cardboard and 200MPH Tape (red to match the car).
I am quite rather unsure of any benefit from it. I am thinking its time for a
Nascar'esque front bumper. Build it all outa aluminum angle, and then use some sheet metal over it, with a nice splitter on the bottom too.
I won't even get started on the wrap around rear bumper / wheel skirts idea... Lol!
- Greg
Old 01-20-2010, 10:16 PM   #20 (permalink)
i did it and am very satisfied with the results
SUPER FLUSH NOW!!!!
how to.....
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 11:55 PM
Honeycomb under a Carburetor TrikeKid DIY / How-to 16 03-08-2010 08:10 AM
Metro death atomicradish EcoModding Central 17 10-06-2008 04:35 PM
