Old 03-30-2008, 02:52 PM   #51 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
RH77
my bad i didn't do my homework
fabrio.-interesting idea on the glow plugs in the coolant. that's a new one. the glow plugs draw 9 amps each.
the diesel having no throttle plate pumps so much cool air through at light load that it cools the engine off going down hills.
Old 03-30-2008, 04:02 PM   #52 (permalink)
British Ecomod Hypermiler
AXMonster's Avatar
The AXe - SOLD - '97 Citroen Citroen AX 1.1i 5 Door
90 day: 46.78 mpg (US)
Foci - '03 Ford Ford Focus Tdci Ghia Estate
90 day: 64.37 mpg (US)
Originally Posted by diesel_john View Post
RH77
The glow plugs in an aluminium block with coolant passing through is nothing new
I was testing one at -30 degrees C about 10 years ago.
Didn't make much difference to engine warmup time on a 1.8 turbo diesel Focus running in a climatic windtunnel.
IIRC The tips of the glow plugs should not go into the coolant or there'll be localised boiling & corrosion of the tips. They should be seated against the aluminium close to the coolant passage..... However this picture shows otherwise (veg oil heater for SVO)
Note the thermistor clamped on the side to regulate the temperature. That probably solves the problem
1997 Citroen AX 1.1i SPI
2003 Ford Focus 1.8 Tdci estate
Ecomods: See my garage
Old 03-30-2008, 07:18 PM   #53 (permalink)
fabrio.'s Avatar
tigra AERO - '96 opel tigra
Hi boys.
I have inquired: the GLOW PLUGS would have to be from 170W.
Not from free air intake that the diesel is more coold than the gasoline, but for the different
efficiency
Old 03-31-2008, 12:49 AM   #54 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
http://sec.edgar-online.com/2000/04/...8/Section2.asp
there is the sec filing for that turbolator device. It has the carb # and some other info that might lead to finding the actual results of the epa test for anyone that is curious. I wasn't able to find anything but I didn't look very hard really.
Old 03-31-2008, 03:02 AM   #55 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
I've heard of this product for a few years, but no results! Perhaps an adjustable potato in the tailpipe could yield some similarity.
Honestly, I crave data on this...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 04-01-2008, 12:01 AM   #56 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
LOL!!! Adjustable potatoes!... ah man... too funny. Would be cool if they existed tho!
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 04-01-2008, 12:12 AM   #57 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Heat = waste
My motorcycle has a terrible heater, but man is it efficient!!!!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 04-01-2008, 02:44 AM   #58 (permalink)
MP$
Smile
adjustable baked potatoeater 3.1
Old 04-01-2008, 09:00 AM   #59 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
diesel john, why the flapper? I thought about a drilled one to help with low end torque, but after all the reading I did I don't think it would do any good...
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 04-27-2008, 09:06 PM   #60 (permalink)
OfficeLinebacker's Avatar
I too have pondered this question and wondered how one could scavenge the exhaust heat to speed warmup.
However there's also another ready source of heat in a car: the brakes. I wonder if there's some way to build a heat exchanger to take advantage of that heat.
Cold air VS Warm Air Intakes - what's the difference? deadman1474 EcoModding Central 63 03-22-2019 10:53 AM
Winter cold start & idling warm-up experiment MetroMPG Hypermiling / EcoDriver's Ed 17 12-17-2010 04:39 PM
