View Poll Results: How long will it take me to replace my heater core
One day. You got this! 4 33.33%
A week or two. 3 25.00%
A month or two 0 0%
6 - 12 months 5 41.67%
Voters: 12. You may not vote on this poll
Old 07-14-2020, 01:58 AM   #71 (permalink)
How to remove a 1996 - 2000 Civic dashboard in 2.5 minutes!
It only took me 1:15 to watch it!
I didn't learn anything, though...
Those are the best videos that I have found, but I still feel that they are inadequate. Can you watch 2.5 minutes of video that are supposed to take at least 2.5 hours and remember everything?
I swear that I already shared these!
California98Civic (07-14-2020)
Old 07-14-2020, 03:33 AM   #72 (permalink)
The dash is out.
Old 07-14-2020, 07:25 AM   #73 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
The dash is out.
Can you do it blindfolded yet?
Old 07-15-2020, 01:03 AM   #74 (permalink)
I got a bad case of the clamps!
I cannot physically remove the dash blindfolded. I am not great at removing it without a blindfold. It is surprisingly light, but what? Five feet wide?
The frame in the middle isn't strong enough to support the weight and I have bent it each time that I removed the dash. I guess that I need to set it on the front or back; there is now a flat spot above the instrument cluster.
So, the clamps stretched?
Where do I find new ones? I could not find them from a dealership or aftermarket, except $10 each from a site that I never saw before.
I guess that I am calling a dealership the first thing in the morning!
Old 07-15-2020, 02:34 AM   #75 (permalink)
Ooh! AutoZone put them in the box!
If CarId sent clamps, I cannot find them. I just pulled the heater core from the AutoZone box. I didn't think about the clamps, I just didn't need a third set of pipes.
Crisis averted!
Old 07-15-2020, 10:47 AM   #76 (permalink)
Auto zone, Nqpa online, or similar local parts supplier may have your clamps but you'll need the proper name for the search.
Old 07-15-2020, 12:48 PM   #77 (permalink)
I called AutoZone when I saw the picture with the clamps and the guy told me to call a dealership for the name and part number, then maybe another chain would carry it, but his didn't. However, I found a set in the AutoZone box. I may have misplaced some from CarId or maybe they are too cheap to include vital components.
Old 07-19-2020, 03:08 PM   #78 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Progress!
Old 07-19-2020, 09:05 PM   #79 (permalink)
I still need to test the heater cores before installing one. I do not want to use the new clamps fearing they will stretch like the originals. I cannot think of anything that I can do besides wrap the joint with a section of inner tube before applying the clamps. I bought one of those skinny metric inner tubes. It may be the right size, but it has a Presta valve!
What am I supposed to do with a Presta valve!
I had wondered about using the valve from an inner tube instead of the method that I used.
One of the old screws stripped and I did not replace it yesterday. None of my Walmart screws fit, but the inner tube and other old clamp seem to work. The tube didn't seem to move at all!
I would have bought a narrower tube if I could have, but I am glad that I couldn't.
Sure inner tubes expand a great deal, but I had not realized how much they inflate inside the tire. I am pretty sure that the deflated width is narrower than it is supposed to be fully inflated.
It took some work to squeeze the inner tube over the tube, but not as much as to spread it over the joint, so I will cut a wider piece for the second one.
I do not want to risk stretching the clamp, but I expect to be able to replace stripped screws, so I went to borrow one of the new ones.
I absolutely cannot find the new clamps!
The other thing is the HVAC system bolts into metal on the top, but into plastic on the bottom, which stripped. The best solution that I found was to epoxy the hole, wrap the fastener with teflon tape, twist them into the hole, and remove it and the tape once the epoxy cured.
I epoxied something else first yesterday and when I checked this morning it was still soft. It is supposed to cure in 15 minutes! It didn't cure in 15 hours!
It is still soft.
I will be installing Helicoils tomorrow, buying replacement screws, testing the heater core, and reinstalling.
Old 07-19-2020, 09:39 PM   #80 (permalink)
Cyborg ECU
That's my current hair do. I blame COVID.
