Old 06-21-2010, 09:18 PM   #21 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I haven't seen that link. How are you computing MPG?
Old 06-21-2010, 09:25 PM   #22 (permalink)
Manual. Fill up full tank. Zero out Trip A mile counter. Drive from central, MD to Richmond, VA ( approx 160 miles) I-95 highway. Fill up again. Trip A miles divided by amount of gas fill up in Richmond, VA. Then do the same for trip from Richmond, VA back to central MD.
Old 06-21-2010, 10:01 PM   #23 (permalink)
dcb
needs more cowbell
dcb's Avatar
And you do this for each change? and have no-change control runs? And a sample size baseline of more than 1?
Old 06-21-2010, 10:17 PM   #24 (permalink)
I was working in MD driving daily from my home in Richmond, VA since July 2007. I started the baseline manual computes since July 2008 (Monday thru Friday) when fuel hit $4/gallon. I started experimenting with hydroxy boosting August 2008. I finally got this setup right in Jan 2009 and stabilized the hydroxy booster design in March 2009. So you see I have been getting 45-50 MPG highway for more than 1 year now.
Last edited by greenfuelbooster; 06-21-2010 at 10:22 PM.. Reason: clearer statement
Old 06-21-2010, 10:29 PM   #25 (permalink)
dcb
needs more cowbell
dcb's Avatar
You are selling this hydroxy booster?
Old 06-21-2010, 10:41 PM   #26 (permalink)
The booster is for sale now ... after almost 2 yrs of research and real drive condition testing.
Old 06-21-2010, 10:42 PM   #27 (permalink)
dcb
needs more cowbell
dcb's Avatar
Wholly crap, you want $700!! <link to paypal removed>
what cars have you tested on?
Old 06-21-2010, 10:45 PM   #28 (permalink)
Boris - '04 Saab 9-3 Linear
90 day: 22.75 mpg (US)
Natasha - '10 Saab 9-3 Combi 2.0 T
90 day: 24.42 mpg (US)
Originally Posted by dcb View Post
Wholly crap, you want $700!! ...
Another mystery solved, Holmes.
Old 06-21-2010, 11:08 PM   #29 (permalink)
First, do not buy online.
Second, do not buy if you are not even familiar with hydrogen generation using electrolysis.
Most of the cost is due to Platinum-cladded Niobium anode.
Old 06-21-2010, 11:21 PM   #30 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
apples and bannanas
Originally Posted by greenfuelbooster View Post
I am moderate hypermiler since Aug 2008 .... My max was only 40 MPG even though I tried to push it. Using this configuration I get at least 45 MPG all the time. The restriction after the MAF gets me 44 already but with less power. The hydroxy gas injection adds power and the rest of the MPG. If you are in the northern VA/DC/MD area we can drive the test route (central MD to central VA) so you can see
You might want to check this PhD study. This might probably explain the hydroxy side.
4shared - free file sharing and storage - share folder - My 4shared
you MAY NOT use this paper / PDF to justify your.... claims
or shall i say ($700) HOAX ?
because
the paper refers to the test results showing benefits of HYDROGEN injection into a lean burn single cylinder engine.
but
you claim to be using HHO called by you HYDROXY otherwise known as browns gas .
it is NOT HYDROGEN it is two molecules of hydrogen with one molecule of 0xygen AND what ever clings on left over from the process you are using for electrolysis . ..
Hydrogen works, HHO does not .
apples and bannana s
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
Hydrogen Generator Experiment willy57 DIY / How-to 601 08-23-2016 05:53 AM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 10:35 AM
Psychological Ways of Saving Fuel Wayneburg General Efficiency Discussion 22 06-06-2008 09:24 AM
