Old 09-22-2012, 09:11 PM   #81 (permalink)
Spdmini's Avatar
SPDwagen - '12 VW JSW TDI DSG
90 day: 35.8 mpg (US)
Originally Posted by jrmichler View Post
google is my friend. I searched with parameters as follows: Site:ecomodder.com acetone
this is ecomodder.com, not eco-somebody-else-do-it.com
yes, this!
http://ecomodder.com/forum/image.php?type=sigpic&userid=28770&dateline=134810  0039
Old 09-22-2012, 09:55 PM   #82 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
Despite EPA mandated emissions control systems and E10 gasoline, I've somehow managed to get over 50% over EPA combined with a 4 liter Ford Mustang without any modifications to my emissions controls or adding anything to my fuel. In fact, I've only had one fill-up that was under the EPA highway estimate. I generally get better fuel economy commuting than on freeway trips. I must be doing something wrong. :shrug:
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
The Following User Says Thank You to Mustang Dave For This Useful Post:
ecomodded (09-28-2012)
Old 09-22-2012, 10:36 PM   #83 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Originally Posted by DoctorM View Post
So much emotional baggage here.
I just mentioned what I read -- to see if anyone here had tried it. I don't have an emotional stake in it as some of you apparently do.
As has already been pointed out, putting it in a vehicle subjects the result to tester bias - pro or con. Until its tested in an engine on a dynamameter, it remains a candidate for further consideration.
Try not to get so emotional about it - it calls into question your impartiality.
Emotion? Care to point it out?
So you're going to pull your engine, put it on a dyno and test this. Great! Let us know what you find out. Btw, I never said it wouldn't work.
Just out of curiosity, how much does acetone cost per gallon?
Old 09-23-2012, 04:40 PM   #84 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.65 mpg (US)
Let's play with numbers. E10 gasoline is 10% ethanol, and (I believe) most cars lose about 2% gas mileage with E10 compared to E0 with the same octane rating. If we could remove the ethanol from E10 using zero energy, then we would end up with 90% as much fuel as we started with. The result would be 2% better mileage on the remaining fuel minus 10% for the 10% less fuel, or a net loss of 8%.
Homedepot lists acetone at $17 per gallon on their web site.
Old 09-27-2012, 09:44 PM   #85 (permalink)
Team Mustang
Sports Cars
Pickups
Here's what Wayne Gerdes had to say on cleanmpg.com -" ___As for Acetone, Bluefuzz, has it right. If Acetone worked (it doesn’t), the manufacturers would have a $15.00 plastic tank filled with the crap and a $30 metering injection pump to feed it into the fuel system vs. the multiple tens of $BILLIONS of dollars the manufacturers spend on new engine technology to achieve even a small increase in FE".
Old 10-07-2012, 02:38 AM   #86 (permalink)
@ JRMichler
@Mustang Dave
You two have way to much faith in your supposed "logic." Your doing a lot of rationalizing. Some people would call that mental masturbation.
Until you actually test an item under very controlled conditions, you don't really know what the relations might be.
Now, I don't really want to hear from either of you again on your unsupported opinions.
Old 10-07-2012, 10:07 AM   #87 (permalink)
Spdmini's Avatar
Old 10-07-2012, 06:08 PM   #88 (permalink)
Old 10-07-2012, 07:59 PM   #89 (permalink)
Team Mustang
Sports Cars
Pickups
@Frank Lee & Spdmini
@DoctorM
Enjoy pursuing your.
JRMichler (10-07-2012)
Old 10-07-2012, 10:11 PM   #90 (permalink)
Milage update
New 2012 Nissan Frontier mileage starting to look better. Here is my mileage plot from fuelly.com
I'm not really doing anything noticeably different, so I got to think this curve is a combination of new engine break-in, computer adjusting to my driving, and me adjusting to the vehicle-computer.
add acetone, add diesel, removing ethanol
