Old 03-19-2014, 10:23 AM   #71 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
Don't forget CAD (Cardboard Aided Design), make it a duck tape sandwich composite for strength/weather. Hot glue (or more duck tape) for attachment, 1" high, follow the fairing from the bottom of the windshield to the bottom of the fairing I recon.
Old 03-19-2014, 05:00 PM   #72 (permalink)
Hi Ironside,
Theo and Allert re-sell the stall strips (storm strips) at their business. I believe some other Dutch velomobile enthusiast manufactures them.
Otto's suggestion for drywall corner protectors is what I would use here in the US. Home Depot and Lowes may not have outlets in England but I'd be surprised if the local "home improvement centers" in England didn't have the same thing. If they don't, a specialty supplier to companies that cater to that business would.
If your curves are of short radius, a heat gun would assist in the bend as the drywall corner protectors here are made of acrylic or styrene plastic and would only bend to a fairly gentle curve. Just don't overheat the plastic.
As Otto suggested, some double sided tape would make attachment easy or if you don't care about the looks (temporarily) just stick them on with a suitable strong single sided tape.
As I have suggested before, a simple vertical fence would be a degenerate form of a stall strip. A suitable flexible strip of plastic or wood taped down would serve for testing purposes. "V" notches , stegosaurus look? would aid in forming a short radius curve. Again, for testing purposes, looks are irrelevant.
Otto's other suggestion to add yarn tufts would be of a lot of interest. Vetter has a very clever method of "mass producing" yarn tufts he details in one of his chapters on his "Last Vetter Fairing". Edit: I found it in chapter 25.
-- Teri
Originally Posted by Ironside View Post
I don't know the optimim size or location, so I thought I could experiment with a stick on plastic strip.
Does anyone know what Theo uses?
Originally Posted by Otto View Post
Try clear plastic L shaped corner piece used to protect corners of sheetrock walls in houses. Comes in 8' lengths, straight but somewhat flexible.
Very cheap at Home Depot or Lowes. Stick on with two-sided carpet tape or sticky foam tape. You could add yarn tufts, record the effects with GoPro camera.
Last edited by Teri_TX; 03-19-2014 at 05:53 PM.. Reason: Found Vetter's chapter on tuft making
Old 03-19-2014, 05:29 PM   #73 (permalink)
Hi Bschloop,
I (and everyone else) would be very interested in some real world A-B-A testing of stall strips on an actual streamliner fairing.
Other than Theo's postings and Dutch blogs on "storm strips" (same thing), all has been theoretical musings since I first posted the idea.
Originally Posted by bschloop View Post
I just found this thread, and I would be happy to test a "stall strip" on my fairing, As soon as the snow melts and my bike is back together. It should be only a week or two now.
Alan and Vic's bikes also have one other thing in common. They are both kawasaki ninjas underneath. It would seem that weight distribution and steering geometry might be more favourable for them compared to other setups. Craigs helix is less than ideal because of its basic design ie. low center of gravity, very small wheels. These are great bikes to compare since they all have the same fairing (for the most part)
Interesting observation. I'm not a motorcycle rider so I have no first hand knowledge and I admit I haven't considered the dynamic aspects of mass distribution. In all, motorcycle design is a very complex system dynamics problem.
Alan's latest project design lengthens the wheel base and weight distribution is changed. We'll have to see how it works out.
I understand the use of Kawisaki Ninjas as a mule due to their cheap availabilty, but for better FE, a single cylinder motor like the Honda CBR 250R's should be better. Not having a screaming engine under or in front of me would be a plus as I'm anything but a wanna be "boy racer". I hear them screaming down the highway near me often in the spring and fall here while waiting (hope?) to hear the scream suddenly stop in a crash.
-- Teri
Old 03-19-2014, 08:34 PM   #74 (permalink)
Found this while searching
MOTORCYCLE BIKER HELMET STICK ON SPIKE STRIP MOHAWK LONG CENTER SPIKE | eBay
should frighten the jaywalkers.
Thanks Teri, I've found suppliers of T section trim and D section conduit that will do the job, also stick on chrome trim which could be used without painting, all available for pennies. I was a scientist in a previous life, so a little experimenting is in order I think.
Also I must thank you for starting this thread, it came at a very opportune moment for me.
Regards
Pete.
Old 03-19-2014, 09:53 PM   #75 (permalink)
Hi Pete,
I love it! Stall strips for helmets!
"D section conduit"? Is that for the add on surface wiring when the power wiring in a building isn't readily accessable?
Regards
Pete.
You're welcome!
Regards,
Teri
Old 03-20-2014, 11:07 AM   #76 (permalink)
Hi Teri,
The conduit I mention is exactly as you describe, I'd prefer to go with a stick on chrome strip (easier and better looking), with a double sided sticky foam tape underneath so that it stands 5 or 6 mm proud of the surface.
I don't know the minimum effective thickness or best cross section shape of the stall strip, so this is the plan :-
1. Make some tufts (Chapter 25 as you said) and stick them down one side.
2. Tape down a piece of rope along the centre line (I have 7mm rope laying around).
3. Rig up a large extractor fan to mimic the wind from different directions and at various angles of lean.
4. Post the video here so that people with more knowlege than me can analyse the results, and hopefully advise accordingly.
Any suggestions before I start?
Pete.
Old 03-21-2014, 02:23 AM   #77 (permalink)
Hi Pete,
Pete.
Your plan is as good as far as I'm concerned.
The height of stall strips is something best determined experimentally as no one here is a PHD brainiac aerodynamicists with years of wind tunnel use (I'm sure someone will falsely claim such curriculum vitae). Just plan on a few experiments with various shapes and sizes. Tuft pictures of the experiments might show something obvious.
Edit: For your tests at various angles, remember the vector sum of a side wind and forward velocity. Tony Foale Tony Foale Designs, article on motorcycle aerodynamics. gives an example of a 15 mph side wind and 75 mph forward speed results in an apparent wind of 76.5 mph at 10 degrees to the over the road direction. I don't expect your fan has such power to make a 76.5 mph wind but the angle is a good start. The idea is to study how your stall strips ruin the airflow on the down wind side and presumeably the unwanted lateral lift. The tufts should indicate turbulent flow at the body surface. Some one has pointed out tuft testing isn't the whole picture but it's a start. Smoke generators are more problematic although possible for some one with excellent shop facilites.
THEN ... road test! As Visionary asked, how do you quantify the results? I don't have an answer at this time. Your best impression is about as good as any opinion on this forum.
Regards,
Teri
Old 03-21-2014, 11:20 AM   #78 (permalink)
I didn't think I'd be posting again so soon, it was another blustery day today with avg. wind speed of 22 mph gusting to 35, similar to my last test run, but with squally shower of rain and hail. A chance too good to miss for a direct comparison.
I took a piece of 7mm rope and taped it down the centre line of the fairing, and went out for a run.
I honestly didn't think such a small change would have such a dramatic effect.
Yes the bike still moved around, but not nearly as much as previously, at no time was I even a little concerned.
In an attempt to quantify the result, I'd say that the bike was affected only by gusts strong enough that I could feel on my body, this was not the case before. I might even go so far as to say that it was not a lot different from riding a 'naked' machine.
Further experiments are planned before a permanent strip is installed (would bigger be better?). Based on today's results but I'd be quite happy to call this fixed.
My camera battery is flat and I can't find the charger , so there will be a delay before posting the tuft testing video.
By the way, apart from my shoulders, the fairing kept me warm and dry.
The Following 3 Users Say Thank You to Ironside For This Useful Post:
jkv357 (03-21-2014), P-hack (03-21-2014), Teri_TX (03-21-2014)
Old 03-21-2014, 05:42 PM   #79 (permalink)
Hi Pete,
BRAVO!
Other than Theo's report on his velomobile, you're the FIRST Ecomodder to test and report on a stall strip like device on a dust bin type fairing. I wish I could give you something more than a thanks on your post!
A few more tests on maybe a bigger rope or similar might give you an indication if bigger is better
However, I'd still be cautious about taking on big lorries (18 wheel trucks for Americans) without more testing.
Regards,
Teri
Old 03-22-2014, 12:23 AM   #80 (permalink)
low&slow's Avatar
l&s' Jag - '00 Jaguar S-Type SE
90 day: 25.86 mpg (US)
l&s' Vision - '82 Yamaha Vision XZ550RJ
90 day: 59.92 mpg (US)
L&S' Greenaero Ninja 250 - '99 Kawasaki Ninja EX250F Ninja 250R
90 day: 97.24 mpg (US)
SilverAero Ninja 250 - '04 Kawasaki EX250 Ninja
90 day: 88.24 mpg (US)
Hi Teri, Welcome to Ecomodders! Interesting discussion about the storm strip in front of the nose. I got into streamlining almost 4 years ago and have enjoyed some success with my bikes. I started with a 1982 Yamaha 550cc Vision got it up to 66.8 mpg then switched to a 2000 Kawaskai Ninja Ex250. With the Ninjette I've gotten a best tankfill of 146 mpg and have Vetter Challenges runs of 130 mpg( 2013 MidOhio, 4th Place) and 119mpg ( 2012 MidOhio, 2nd Place) . I ride my streamliner on a regular basis and have ridden it from the SF Bay area to Kentucky and back. I run a Vetter fiberglass nose and I built a Vetter-style tail using plywood, doorskin and fiberglass. I'm good friends with Craig Vetter, Alan Smith Terry Hershner and Fred Hayes.
Craig's , Alan's, Terry's and mine are pretty similar in profile. All us do pretty well in windy conditions though Craig's struggles a bit more than ours. We suspect is due to the Helix scooter steering geometry , low center of gravity and small wheels.
I agree that the Honda cbr250r is a good choice as your base platform. Single cylinder , fuel injection and water- cooling are all desirable features. Sendler has had great success with his. The Ninja 250 is cheap, durable and does surprising well despiteits sport tuning. Good luck with your efforts !
aerodynamics, allert, vetter fuel challenge, wind tunnel testing
