Old 02-01-2012, 07:05 PM   #61 (permalink)
Rapturee
HHOTDI's Avatar
Sippy2 - '15 Honda NC700XD DCT
90 day: 59.51 mpg (US)
Shorty - '02 Ford F150 XL
wow...7mph! that is good to know. :{)
Old 02-01-2012, 07:54 PM   #62 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
how many miles can a non Oring chain last while riding in the rain on the highway?
The Following User Says Thank You to sendler For This Useful Post:
HHOTDI (02-01-2012)
Old 02-01-2012, 08:15 PM   #63 (permalink)
Rapturee
HHOTDI's Avatar
properly and regularly oiled, i'll bet a long time. that has been my experience with the one on my Xt350. Mud, snow, sand-dirt and buried in muddy water often...lol, you know how it is. I will certainly be using one on my Diesel bike. If you can get that kind of mph, i am wondering what the MPG increase will be, even a few is worth it! I sure appreciate you guys, your experience/input and knowledge. It is noticed and much appreciated! :{)
Old 02-02-2012, 11:03 AM   #64 (permalink)
low&slow's Avatar
l&s' Jag - '00 Jaguar S-Type SE
90 day: 25.86 mpg (US)
l&s' Vision - '82 Yamaha Vision XZ550RJ
90 day: 59.92 mpg (US)
L&S' Greenaero Ninja 250 - '99 Kawasaki Ninja EX250F Ninja 250R
90 day: 97.24 mpg (US)
SilverAero Ninja 250 - '04 Kawasaki EX250 Ninja
90 day: 88.24 mpg (US)
Non O-ring chain it is then , thanks for the info.
I interviewed for a new part-time job yesterday so this may slow down my progress a bit. I think the Gear Commander provided info on chain length changes when changing sprockets.
Old 02-02-2012, 03:23 PM   #65 (permalink)
Sweetie - '11 Hyundai Sonata GLS
90 day: 39.35 mpg (US)
My Miles - '03 Combo GLS/KLX/Ninja
90 day: 40.49 mpg (US)
Sipper' - '04 Kawasaki Ninja 250
90 day: 74.98 mpg (US)
Long enough to drain the tank and have to re-fill it, in which while stopped you can re-lube, if required of course.
Excess lube is what makes dirt and grime stick to a chain, which is abrasive and can wear them far faster than a clean chain with no lube.
This ain't a war, anymore than a war between men and maggots. Or, dragons and wolves. Or, men riding dragons, throwing wolves at maggots!
Old 02-02-2012, 04:19 PM   #66 (permalink)
sendler's Avatar
I guess a Scott Oiler would be a good investment if you rack up any miles.
Old 02-02-2012, 09:51 PM   #67 (permalink)
low&slow's Avatar
Scott oiler? I'll have to check it out. After the shock of getting back into chain maintenance after 28 years with a shaft bike, I'm suprised to find chain lubing and adjusting is pretty easy. I'll check out the oiler, I have heard good things about them.
Thank you, L&S
Old 02-04-2012, 10:35 AM   #68 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
as requested !
I ordered a 15 tooth front countershaft sprocket and hopw to receive it soon. I may go with a 39 tooth rear sprocket later. I also replace the seat with one I made for a lower seat height. I rode it yesterday and today and it seemed to dowell in the wind, better than the Vision.
(Based on your post #12)
I kind of had to cringe when I saw the nice front wheel covering in your pictures above.
Many years ago, I made a beautiful foam/fiberglass front wheel fairing.
How did it work out you ask?
With no traffic around me, it was great!
But be in close quarters with a semi-trailer truck, is was awful. I lost almost all control of the front wheel due to the buffeting tumbling off the back of the trailer!
Very scarey!
(See Bryan's post at #18 as well; thanks Bryan)
https://picasaweb.google.com/threewh...orcycleFairing
Jim.
Old 02-04-2012, 11:36 AM   #69 (permalink)
low&slow's Avatar
3wheeler, Thank you for your concern. I have ridden my Ninja several hundred miles, often in windy conditions and in close proximity to trucks without issue. For the future I plan to go a frame-mounted dustbin style fairing for the front.
I did encounter handling issues with the fully faired front fender on my Vision. I conferred with Alan Smith who has ridden thousands of miles with his fully faired fender and he advised me to starting raising the bottom edge behind the fork. This worked well and restored my confidence in riding it in windy conditions. The Vision is not as good as the Ninja in handling wind turbulance but I haven't found it to be unmanageable.
Beautiful work on your fender and kudos to you on your Alienmobile!
The Following User Says Thank You to low&slow For This Useful Post:
3-Wheeler (02-06-2012)
Old 02-04-2012, 04:27 PM   #70 (permalink)
low&slow's Avatar
Thumbs up
I refilled the Ninja today and the results are .... 104.35 mpg!!!!!
Needless to say , I'm very happy with this and am suprised that I was able to break the 100 mpg barrier so quickly. I was hoping for a tankfill in the 80mpg range and now this. I have mentioned in previous posts I was impressed with how easily the bike was running with the 15/41 sprocket combo and I was looking to bump it up some more. I thought I would need to do this to break into the 100mpg range. What a pleasant surprise.
Thanks to you all for your support, advice and encouragement. It means a great deal to me and I truly appreciate it.
Low&Slow ( Vic)
HHOTDI (02-06-2012)
