07-21-2023, 05:19 PM
#731 (permalink)
Rivnuts really like to pop out of the plastic trim versus the metal sections. Second time this has happened in different spots
07-22-2023, 09:04 AM
#732 (permalink)
The upset section is a minor diameter increase, not enough to stop or avoid the plastic elongation. Do you have enough space to put a washer on the back side or is it a truly blind install?
07-23-2023, 10:41 AM
#733 (permalink)
Use special nuts instead:
The Following 2 Users Say Thank You to alexshock For This Useful Post:
08-01-2023, 01:41 AM
#734 (permalink)
https://link.springer.com/article/10...48-021-03334-0
abs sheets should be coming this week to make the finalized side cavity fins
The Following User Says Thank You to Phase For This Useful Post:
08-02-2023, 10:10 PM
#735 (permalink)
May try pizza pans for front wheels but not liking the “ curve” on the edges. Any suggestions for a super flat but sturdy material I could use as a wheel cover?
08-03-2023, 12:08 AM
#736 (permalink)
Why would you want super flat? A slight crown adds strength. Flat surfaces will show any imperfection when they are rotating.
Get some (oversize?) pizza pans, drill a small hole in the center and spin form them just like Moon does. Steel would be harder than aluminum, but I think two handheld caster wheels might do it.
.tragectory: Line goes down and to the right.
08-03-2023, 01:22 AM
#737 (permalink)
id only attach them for long road trips because constantly applying duct tape is a pain. id do thin abs plastic, but cutting a perfect circle would be too hard
08-03-2023, 12:41 PM
#738 (permalink)
wheels
MOTORTREND aero-modded a Porsche GT3 for a long-distance mpg test and made 'janky' coroplast wheel covers, zip-tied onto the wheels.
Just to see what they did, you might cobble something like that together, just long enough to see if they made a showing.
'Flat' covers make a great diaphragm, drumhead. You'd have to appraise how much your wheels could support them against 'flutter.'
08-03-2023, 11:54 PM
#739 (permalink)
do you have a link to that test?
08-07-2023, 12:06 PM
#740 (permalink)
Aero Wannabe
I have experimented with flush coroplast wheel covers. You can make a compass out of an old yardstick with a hole drilled for a screw to spin it in the coroplast and another hole for a sharpie marker. Cut them out with old fashioned tin snips. I used 3 wire ties each and just snipped them to remove them. I did a study of them if you search posts started by me. There was a slight improvement but I think I get more of an improvement from my homemade belly pan/diffuser.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
