Old 08-07-2009, 12:13 PM   #61 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
So what about adding sheet metal fins to the hot side? To help cool it better?
Old 08-07-2009, 02:18 PM   #62 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
That would definitely work, but that's essentially what the condenser is, a set of tubes with aluminum fins stuck to them to increase surface area a hundredfold.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 08-07-2009, 05:01 PM   #63 (permalink)
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 38.64 mpg (US)
Great idea. I don't use A/C that much but I might do this anyway, probably only cost a few bucks for the insulation, right?
My dad has a '95 Escort wagon with the 1.9 and a stick. I guarantee you he is not getting anywhere near 40 mpg!
Old 08-07-2009, 09:03 PM   #64 (permalink)
Couldn't hurt, though?
Old 08-08-2009, 12:42 AM   #65 (permalink)
gascort's Avatar
agreed, but it would be much harder than insulating the cold (low pressure) side.
Old 08-08-2009, 12:53 AM   #66 (permalink)
Oh, I never suggest "in lieu of", rather "in companionship with."
IOW - Insulate the cold side as much as possible, then put fins on the hot side, as good measure, with some aluminum/tin scraps and bits of solder.
Frankly, a full-on Redo of the A/C system is probably in order on most cars, placing the bulk of the cold side lines inside the car so that they stay at the ambient temp of the inside of the vehicle, meaning that the system gets more efficient the longer it's on, by keeping the lines cold lines colder, thus cycling the pump less.
Old 08-08-2009, 07:53 AM   #67 (permalink)
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Oldsmobile Intrigue GX
Last 3: 25.94 mpg (US)
...doing even better - haven't used enough fuel since the Kammback to reflect in my logs, but I don't think I've had a tank average under 44.4 mpg since installing it.
Kammback, you say??? I remember us talking about that at the "Meet in the Heat" in KC. Do you have a thread, or pics somewhere???
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
Old 08-08-2009, 10:21 PM   #68 (permalink)
gascort's Avatar
Dan, I can't believe you missed it!
Scientific Method meets Fuel Economy: Kammback
and the thread about it here:
http://ecomodder.com/forum/showthrea...-mpg-9185.html
Did you miss my most recent mod too? We discussed it a bit in K.C. as well, with the battery and alternator discussion:
http://ecomodder.com/forum/showthrea...roof-9549.html
Old 08-08-2009, 10:44 PM   #69 (permalink)
Intrigued's Avatar
COOL!!!! I like the "Scientific Method" bit...
I've been so busy with Drury University that I haven't been on here for a month or better. Just turned in the last Final paper yesterday...
I'm hoping to do some catching up!
Old 08-18-2009, 12:55 PM   #70 (permalink)
College Student
Over 44mpg is impressive. I'd like to get something above 35. Fortunately I hardly ever run my car at school so it's not as important. Adding sheet metal sounds interesting... a little overkill for me though.
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 148 08-12-2021 10:53 PM
Experiment: smooth wheel discs tested A-B-A - 4.6% mpg improvement @ 65 mph Concrete Aerodynamics 318 01-19-2015 11:37 AM
Pulse&Glide, and aero mods, big mpg increase. Sulfuric Success Stories 3 01-15-2009 11:57 AM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 07:46 AM
