Old 08-10-2011, 12:12 PM   #1 (permalink)
Muscle Car Modder
Floordford's Avatar
QuikSilver - '00 Ford Mustang GT
90 day: 24.7 mpg (US)
Momentary switch to kill fuel
Im trying to EOC without turning off my ECU then turning it to the on position again after the engine is off. Id like to just kill the engine. My question is, has anyone wired up a switch to the fuel cut boxes in the front and rear of the car. They trip to the off position, cut fuel pump power and need to be reset after an accident. Seems like I could break the circuit going to one of those boxes to shut the engine off. Anybody done it that way?
2000 Mustang GT
273hp/ 309ft.lbs.
Cd 0.36 Im working on it
Old 08-10-2011, 12:18 PM   #2 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
I don't think it will cut the fuel as quickly as disabling the injectors. Your injectors will still operate until the fuel pressure drops.
I'm not coasting, I'm shifting slowly.
Old 08-10-2011, 12:40 PM   #3 (permalink)
in tents
dennyt's Avatar
The Adventure Wagon - '94 Subaru Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '11 Surly Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
Agreed, you will waste a lot of fuel and run lean as the fuel pressure decays and the injectors keep firing. You should look for a way to cut the injectors off.
This is the one advantage of my throttle-body injector - just one wire to interrupt!
Old 08-11-2011, 12:58 AM   #4 (permalink)
Muscle Car Modder
Floordford's Avatar
I didn't think about that. Ill have to figure out how to shut the injectors down. Im sure ill be a pioneer in this venture as there arent any other Mustang guys doing this.
2000 Mustang GT
273hp/ 309ft.lbs.
Old 08-11-2011, 03:10 AM   #5 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I agree about the pump being problematic for this purpose. My injector kill switch rarely shuts the ECU down. Cuts the engine immediately. Blinkers, Odo, Speedo--all continue functioning normally. Cut the ground to the injector relay. Check out my write-up: http://ecomodder.com/forum/showthrea...tml#post254910. Though it is for a Civic, I hope it can offer something useful to you. Good luck, james
OH! Post your results and build when you get them...
Old 08-11-2011, 09:55 AM   #6 (permalink)
I agree that the fuel pump is not the way to go. Here is how I did mine. Not a Mustang, but a Ford.
http://ecomodder.com/forum/showthrea...tch-15943.html
On your engine, the common feed wire to the injectors is red also.
Old 08-11-2011, 01:43 PM   #7 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Just a note on my Bonneville I can cut the power to the fuel pump and at idle it will run for 10-30sec before it stumbles and kills the engine.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 08-11-2011, 07:26 PM   #8 (permalink)
Muscle Car Modder
Floordford's Avatar
Had to do some digging but I found that my injectors also run off of a central red wire. But they also power other things after the injectors off that same wire. I may try a crude toggle switch to see if it throws a CEL. If it does its back to the drawing board. If im good then ill need to find a normally closed momentary push switch that can take that current all the time.
2000 Mustang GT
273hp/ 309ft.lbs.
Old 08-16-2011, 12:00 PM   #9 (permalink)
Phantom's Avatar
If you have a hard time finding a switch that will work you might be able to use a relay that is driven by the momentary switch.
Old 08-16-2011, 12:21 PM   #10 (permalink)
Muscle Car Modder
Floordford's Avatar
So you think a common 40a relay would do?
2000 Mustang GT
273hp/ 309ft.lbs.
