Old 08-06-2018, 12:00 PM   #431 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by pgfpro View Post
Pic of a log running lean burn.
So this shows an AFR maybe 27:1 ?
pgfpro (08-07-2018)
Old 08-07-2018, 12:30 AM   #432 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
71 Camaro - '71 Chevy Camaro
White Pearl - '26 Toyota Prius SE
By the math it should of been around 29:1 AFR. That was under perfect conditions.
The car has been through a bunch of changes, at the point I needed to make it safe to race so it now has a cage and a lot of safety gear. The good news its about 200lbs lighter, the bad news it has a race head on it with race cams and all the FE items removed.
ID:	24650   Click image for larger version
ID:	24651   Click image for larger version
Pressure Gradient Force
The Positive Side of the Number Line
Old 08-07-2018, 05:07 AM   #433 (permalink)
pgfpro (08-07-2018)
Old 03-06-2022, 05:07 PM   #434 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Thinking about bringing the Talon back to FE standards lol
Old 03-06-2022, 05:29 PM   #435 (permalink)
Good to hear from you again!
The current situation is drawing interest back to fuel economy. Not everyone can afford a Tesla.
The Following User Says Thank You to RustyLugNut For This Useful Post:
pgfpro (03-06-2022)
Old 04-03-2022, 08:13 PM   #436 (permalink)
I've been re-reading this entire thread twice a year r so for the last 6 or so years. I'm always amazed at what you've done here.
I wanna see if you can push it even further!
The Following User Says Thank You to warlocksyno For This Useful Post:
pgfpro (04-04-2022)
Old 04-04-2022, 09:16 PM   #437 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Thank You!!!
I've decided to make it a dual purpose FE/HP car. I'm going to detune the engine and make my 71 Camaro the high HP car from this point forward. As of now the Talon is the test bed for GEM fuel that the Camaro will inherit. The Camaro will be a 4G63 2.0L turbo compound setup that will make around 1300HP.
The Talon will have a new turbo that is a 51mm compressor wheel compared to the 61mm its running now. The exhaust turbine wheel/housing will be much smaller also. I'm going to install my old lean burn/low lift head back on it with the FE cams. I'll add all the new information here and resume my FE garage mpg status.
Camaro Engine
The Following 2 Users Say Thank You to pgfpro For This Useful Post:
19bonestock88 (04-08-2022), deanznz (11-05-2023)
Old 04-08-2022, 01:20 AM   #438 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
I’ve followed your build for a long time and am excited about I see you push forward in economy, just in time for me to watch closely and gather notes for my Ecotec based project
My current Ecotec project...
My last Ecotec project...
The Following User Says Thank You to 19bonestock88 For This Useful Post:
pgfpro (04-08-2022)
Old 04-17-2022, 11:40 AM   #439 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Cool Video.
https://youtu.be/jeUEEfnr5-k
Old 04-22-2022, 09:24 PM   #440 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Originally Posted by alehandro View Post
I've heard that this car has chronic problems. Is this true?
You heard wrong, no issues since the engine was built back in 2014.
The Following User Says Thank You to pgfpro For This Useful Post:
freebeard (04-23-2022)
bio fuel, lean burn, turbo compound
