Old 10-31-2022, 12:03 PM   #451 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I always come away amazed at what you create.
It's one of the main things that keeps me coming back to Ecomodder.
Do you have any ideas rendered out on the look of the car when you finish the motor work ?
The Following User Says Thank You to Cd For This Useful Post:
pgfpro (10-31-2022)
Old 10-31-2022, 10:04 PM   #452 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Thanks for the kind words.
I have one in my mind but not anything on paper. I wish I was artistic enough to draw something up.
Pressure Gradient Force
The Positive Side of the Number Line
Old 11-05-2022, 10:30 AM   #453 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
I added a Ecomodder link to my Camaro build. I forgot to when I first put it up. I'll make sure to add it to the new video explaining the lean-burn system.
Old 11-06-2022, 03:05 PM   #454 (permalink)
Growin a stash
You've got the skills and the interesting projects to probably become a full-time YouTuber, if you want to. I'll subscribe.
So, what's the drawback of a 70-mpg, 1400 hp vehicle? High emissions? Strange fuel required? Poor durability? I'm just wondering why it's not done by everybody.
2024 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
The Following User Says Thank You to ME_Andy For This Useful Post:
pgfpro (11-06-2022)
Old 11-06-2022, 08:40 PM   #455 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Thanks' and please Subscribe and Like, much appreciated.
The draw backs in today's world are you're not supposed to mess with factory emissions. Thanks for bringing up a key point I keep forgetting to mention. Since the car is a 1971 Camaro the only emission device is a PCV valve. lol This helps me a ton because it's pretty much exempt.
Poor durability will be one of the issues based on the high HP from a 2.0L. When it comes to FE there aren't issues so far with the pre-chamber and lean burn.
Another reason people wouldn't like car is drivability. When the car goes into high lean-burn it feels like the engine is not right. It lays over until you get it out of the lean-burn hole.
One other major drawback is I have two sets of cams one set is for FE and the other for HP. On the Camaro this will be very easy to swap because I will have easy access to the cam belt and can change them in less than an hour. On the Talon it's a pain and takes me about three hours. I also have two sets of lifters one set is for FE and the other HP. The HP ones are just stock lifters the FE lifters are a custom set that one of the intake valves has a built-in bleed valve that delays the opening event and also opens only halfway to promote swirl.
Next year's FE test will be done during the Summer on a perfect road with hardly any wind. I'm setting up perfect conditions that can get 8 miles more mpg. Another major factor to produce great numbers.
Thanks again more videos will be coming even though I suck at it.
EDIT: Also, I forgot mention it will have a set of FE wheels/tires and a set of racing wheels/tires. When running the FE wheels/tires it will have lower wheel opening skirts.
The Following User Says Thank You to pgfpro For This Useful Post:
Joggernot (11-20-2022)
Old 11-13-2022, 10:50 PM   #456 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Posted my new YouTube video of my waste solvent setup.
I also put a link to Ecomodder in the description.
I'm will have another video later this week showing a slow-motion vid of the pre-chamber shooting out its turbulent jet
https://youtu.be/WJqYGJIYWaY
Old 11-19-2022, 11:11 AM   #457 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Some more video of the Pre-Chamber flame.
https://youtu.be/zKcLteOkpoc
redneck (11-19-2022)
bio fuel, lean burn, turbo compound
