Old 05-07-2012, 10:21 PM   #21 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Originally Posted by 1812rob View Post
I'm going to use the torque app for now which will display the mpg, vacuum, and tps...the scangauge will display the same data correct? Or does the scangauge do additional tuning to the ecu?
I'm not certain of epa testing but i do know that my car is overrated compared to the Honda crz which is rated at 31/37 (lower than my Hyundai) and we all know that the crz and Hondas in general easily surpasses the epa.. something doesn't seem right..
Good news though by using dwl technique and no shoe I'm looking at a 44mpg tank so the technique is working excellent so far
ScanGauge doesn't tune the engine; won't override the car's computer.
Scangauge II will display four out of about 20 different gauge items including mpg. I use it for volts, engine coolant temp, and throttle position but there's a lot more it will show. ScanGauge e only displays two items but you have a variety to choose from.
As far as trying to reach EPA, sometimes it's a challenge (that's not news). My son's '05 Elantra doesn't achieve its EPA # either. Do shift as low as possible. It's a performance car of sorts so it wants to be zippy; do what you can to keep the rpms down. But you probably don't want to go near lugging it while breaking it in.
Coast long and prosper.
Old 05-08-2012, 10:09 AM   #22 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
If your driving conditions match the conditions of the test and your driving style matches the style of the test driver, then the numbers are going to be accurate. Later this summer when I ditch this job and get something that doesn't have me driving 90 miles a day, my MPG is going to plummet. I'm not going to be any less of a hypermiler, even if my sig stops calling me one.
The EPA rating is just a benchmark. That's all.
Your MPG may plummet, but if it drops from 30 to 24, and you cut from 90 miles/day to 20 miles/day, you're still saving gas.
Old 05-08-2012, 10:21 AM   #23 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
I'll be lucky to see 20. I'll also be driving maybe 2 or 3 miles a day, getting some great use out of the bicycle as well.
Transmission type Efficiency
Old 05-08-2012, 04:49 PM   #24 (permalink)
2012 Hyundai Veloster
Vee style - '12 Hyundai Veloster Style
Unhappy
UPDATE
So i was ecstatic for this tank of gas i was at half tank and nearly 300 miles in an likely would have smashed a 500 mile tank and been about 44mpg
On my way home from a 12hr night shift i was lugging along keeping constant throttle positron and threw a cel.. didn't notice driveability issues until i hit a stop light and realize i had power loss at low rpm...10 miles later knock and plumes of white smoke... Towed to dealer and 2 Pistons lost compression and oil soaked plugs...
Still awaiting final diagnosis but a new long block is on order... My break in was about 3k where i drove somewhat aggressive at low <4k rpm i am so confused at how low rpm hypermile techniques would blow my motor
Old 05-09-2012, 09:13 AM   #25 (permalink)
Rat Racer
You didn't. Manufacturers have warrantees because they don't think the parts are going to break in the first place, but sometimes they do. Don't worry about it.
Old 05-09-2012, 09:26 AM   #26 (permalink)
If you were lugging the engine, it *could* have accelerated an already present problem.
I agree with Charlie - cars have warranties for a reason. There's always a percent of manufactured items that do fail; you happened just to be unlucky enough to get one.
Old 05-09-2012, 10:38 AM   #27 (permalink)
Originally Posted by Thymeclock View Post
If the tire supposition were true, then we should notice a drop in MPG every time we buy new tires..
Many people here have noticed a drop in mileage when new tires are installed. Its a pretty well known fact that having less tread on the tire leads to lower rolling resistance.
Old 05-09-2012, 10:45 AM   #28 (permalink)
Maybe I'm buying better quality tires than some others do. Also I don't always wait until tires are worn down to the tread wear indicator to replace them. For me safety is a higher priority than hypermiling.
Old 05-09-2012, 12:59 PM   #29 (permalink)
Rat Racer
How much tread do you need to feel safe? In a New England winter it's nice to have a lot, but in general you don't need much. Any tread at all is usually enough.
Old 05-09-2012, 02:03 PM   #30 (permalink)
3 miles per day, 5 days per week @ 20 MPG = 0.75 gallons used /week.
90 miles per day, 5 days per week @ 30 MPG = 15.0 gallons used /week.
I'd say you'll be coming out ahead.
