Old 05-25-2022, 01:07 AM   #81 (permalink)
The importance of proper grounds has been covered quite extensively on this site. We've found 1 or 2 tricks to use grounding to improve fuel economy a little more than stock.
Recovering Gasaholic
Old 05-25-2022, 01:38 AM   #82 (permalink)
90 day: 89.66 mpg (US)
Though, something to watch out for is ground loops. Counterintuitively, adding more engine grounds (rather than, say, swapping the existing ground wires out for bigger ones) can cause all manner of odd behavior in sensitive modern electronics.
I work in the low voltage field and landing both sides of an electrical drain can prevent sensors from working entirely. I can't count the number of times I've had to cut grounds technicians placed at both ends. If the ground paths are properly engineered to begin with (a big if), I'd be wary of changing the number.
Lin0 (03-27-2024)
Old 05-25-2022, 04:46 AM   #83 (permalink)
Ecky, I believe you are mistaken. If you missed it.....
Combustion efficiency converts to Mechanical efficiency and reduces thermal losses since less fuel needs to be burned.
Instead of burning fuel and massing pressure on the piston during the critical crank angle degrees between 15 and 30 after TDC, fuel is burned in the catcons at 1800 degrees Farenheit in the upstream and downstream catcons. Seems like lots of waste to me that could be reduced.
Old 05-27-2022, 08:15 PM   #84 (permalink)
Since liquid fuel cannot burn, many inventors have found benefits by heating the fuel. At the extreme, heating the fuel to <500 degrees F guarantees 100% vaporization. is probably the most famous guy to prove this concept. One of the MPGenie pages deals with practical ways to get benefits from heating the fuel: Combustible Caliente.
The Following User Says Thank You to mpgmike For This Useful Post:
RealityRacer (05-28-2022)
Old 05-30-2022, 02:35 AM   #85 (permalink)
#13
[ quote ]A magnet is any material that has a magnetic field. The effect magnetic field on the biological and mechanical systems is the subject of study of interest from last fifty years. Many studies suggest that magnetic
field has positive effect on the performance of the system.[/img]
Did you mean to have "[ quote ] [ / quote ]"
#14
20% reduction in brake specific fuel consumption is a tall claim, considering BWM
Did you mean BMW?
#15.
I want to pontificate
You wanted to speak or express opinions in a pompous or dogmatic way?
Ecky (05-30-2022)
Old 05-30-2022, 03:18 PM   #86 (permalink)
Fair enough, Xist. Points taken; grammar, punctuation, and spelling matter -- even on an internet forum.
The Positive Crankcase Ventilation (PCV) system has not changed much since introduced for the 1964 model year. However, there are things we can do to clean up the toxins in the gasses, and tricks to put PCV to work for better fuel economy.
RealityRacer (06-04-2022)
Old 05-30-2022, 09:55 PM   #87 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
71 Camaro - '71 Chevy Camaro
White Pearl - '26 Toyota Prius SE
Great thread!!!
Going to take some time to digest all of this but I'll have some of my own info/experience here in a few.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
mpgmike (05-31-2022)
Old 06-02-2022, 02:18 PM   #88 (permalink)
I know the Gadgetman Groove has been explored on this site in the past. I had the opportunity to do some unique testing with the late Ron Hatton himself overseeing the process. It was tested on a flow bench for static flow, and tested on an automobile using a MAP sensor and O-Scope for dynamic characteristics.
Old 06-02-2022, 05:26 PM   #89 (permalink)
I'd heard a lot lately about misinformation/disinformation/malinformation. Is it creeping into Ecomodder or is it just an example of Poe's Law?
ecomodder.com/forum/showthread.php/new-motor-additive-40271
Old 06-02-2022, 05:38 PM   #90 (permalink)
I wouldn't know until I tried it. There have been a few gizmos over the years that looked like total poppycock. They just capitalized on laws of physics I hadn't yet learned. One good example is Orgone, Ki, Chi, Life Force Energy, and a few other names. I bought lots of material from H&A Industries (Bowling Green, MO) from Harold Kneiss back in the 90's, before the internet. One of the "books" (more like a cheap photo-copied pamphlet) said to wrap your fuel tank in alternating layers of aluminum foil and wax paper. The claims were upwards of 40% better fuel economy with a noticeable improvement in performance. I read over it and tossed it in the trash. Years later I learned of Wilhelm Reich and his Orgone studies. I have since done numerous experiments on both ICEs and food preservation. I can attest there is something to it.
There are other examples, but I try hard not to discount something simply because I haven't yet learned enough to understand it. Most often, if it looks like crap, it is. However, I have been surprised and embarrassed by my lack of knowledge in the past. It has been my open mind and willingness to test and verify that has allowed me to learn much of what I now know.
