Old 02-15-2009, 10:20 AM   #311 (permalink)
OBDuino coder
Magister's Avatar
Titine - '13 Hyundai Sonata Hybrid
When the RPM goes to 0, I save all trip data into the EEPROM, no need of a button cell, and EEPROM can be saved 100'000 times.
Also for the CAN version I can put it in sleep mode and it will be woken up when there is activity on the bus. It will draw a few µA only.
2013 Hyundai Sonata Hybrid
Old 02-16-2009, 09:00 PM   #312 (permalink)
RPM will never reach zero
The RPM will never reach zero with the configuration I have. I am using the iso version(not using elm chip), and as soon as the car is shut off, the communication stops with the obduino and the obduino "freezes". (I guess the ecu doesn't run when you put the car to acc.)
I assume this is because it is getting stuck trying to receive a data packet from the car and that it can not go any father or save the data once the car is shut off because it will always be waiting for a packet.
looking at the code in the receive data function there is a line of code that is something like while(receive()==-1).
Would it be hard for there to be a timeout function added. and upon failure it will save its trip data and reset itself so it can attempt to reinitialize with the car?
Old 02-17-2009, 09:16 AM   #313 (permalink)
OBDuino coder
Magister's Avatar
Interesting, on my car when I shut down the engine, the ECU still answer for maybe 5 seconds before giving a timeout.
Yes in the receive function, a timeout should be inserted in the while, something like:
Code:
int iso_read_byte()
  byte t=0;
  int b;
  while(t!=500 && (b=serialRead())==-1)
    delay(1);
    t++;
  return b;
and the result of the function should be tested, if it's -1 it's a timeout
Old 02-17-2009, 11:46 AM   #314 (permalink)
Thanks for the quick reply, I will test it out.
Just a side not, the limit should be less then 256 not 500 if we are going to use a byte for t.
Old 02-17-2009, 12:19 PM   #315 (permalink)
OBDuino coder
Magister's Avatar
lol yes you are right for the type, put either an int or put the limit to 255
Old 02-17-2009, 09:53 PM   #316 (permalink)
I just modified it to this, and now it saves the trips and will even resume reading the data once the car is turned on.
Code:
int iso_read_byte()
  int b;
  byte t=0;
  while(t!=250 && (b=serialRead())==-1) {
    delay(1);
    t++;
  if (t>=250) {
    b = 0;
  return b;
*Bug* This works great. The only problem is that once the car is turned off, throttle position is going to be reported as 0. this means that engine breaking will no long be accounted for. That should be taken into consideration else where in the code if you use this (i.e. reset the throttle position minimum value when ever the car is started up again.)
Old 02-19-2009, 08:41 AM   #317 (permalink)
The Altima - '97 Nissan Altima GXE
90 day: 20.34 mpg (US)
I'm currently porting this software to the Sanguino under the Arduino version 0013 software. But, I'm having trouble getting the MCZ33290EF interface IC. Mouser and Digikey are sold out, and the best estimate was a May delivery time. Does anyone know where I can get one of these
Old 02-19-2009, 09:19 AM   #318 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
You can get up to 2 of them for free from Freescale Electronics as a "sample."
Old 02-21-2009, 06:07 PM   #319 (permalink)
Passat - '09 VW Passat
Last 3: 29.89 mpg (US)
Hi all,
I'm pretty new with arduino coding, and have been away from coding in general for a few years. I just downloaded version 121 of the source code and tried compiling it but I get an error:
In function ‘void params_save()’:
error: invalid conversion from ‘const void*’ to ‘void*
with reference to this line:
eeprom_write_block((const void*)&params, (void*)0, sizeof(params_t));
Can anyone lend a hand? I haven't changed the code and am tried to compile for ISO. I tried Arduino-0011 to 0013.
Thanks.
Old 02-22-2009, 06:23 AM   #320 (permalink)
Originally Posted by Justin K View Post
Hi all,
Thanks.
Heh, I'm having the same problem using 0013A on Mac OSX. My friend successfully compiled for the Arduino Duemilanove on version 0012 under Windows XP though...
Man, I hate winter.
obd2
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 4 06-01-2015 04:58 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 04:57 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 10:04 PM
