Old 07-14-2011, 04:12 AM   #731 (permalink)
I am using exactly this version v191.
I just enabled temp sensors and thats all what is changeed.
I am not programer to know read program code well and it would be very nice if you tell me where can I find those tracking of miles/km or the tracking of fuel quantity values and describe to me how to shange it.
Old 07-14-2011, 04:24 AM   #732 (permalink)
Just show tank distance and tank fuel used used on screen.
Wich of them is wrong?
Old 07-14-2011, 04:44 AM   #733 (permalink)
tank distance with full tank is around 800km
tank used 59L
from my calculatio consumption is less than 7,5 L/100km. In the city this consumption should be bigger around 9 L/100km
But why this value decresing with time while driveing. When I stop with car average cons is bit increaseing but when I go forward it is decreasing again.
I do not know what to do to fix it
Old 07-14-2011, 04:49 AM   #734 (permalink)
59l and 800km is from car odometer?
what numbers are shown in OBDuino (km and L)?
average is calculated from distance and all fuel used. one of them is wrong in OBDuino. which one?
Old 07-14-2011, 04:57 AM   #735 (permalink)
kilometers are from car odometer. Maybe I made misktake in calibration?
I filled up my thank and put that value in THANK USED in obduino
after some thime when I wasted fuel I just read car odometer and that value (800km) put in the TANK DISTANCE in obduino. Is it wrong?
Can you describe how to calibrate obduino?
Old 07-14-2011, 05:04 AM   #736 (permalink)
Set Tank distance back to zero, and Tank used zero too.
Do not use them unless you why and how to use them.
They are for used part of tank after last fill. not for "full tank values".
Just use "Tank size".
And do not forget to reset tank trip after next tank refill. (LEFT and MIDLE buttons pressed together).
Old 07-14-2011, 05:08 AM   #737 (permalink)
OK I will try that and inform you about results.
Thank you anyway.
Old 07-14-2011, 05:10 AM   #738 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
here is the page on mpguino calibration, most of it should apply here too
Mpguino calibration - EcoModder
Old 07-15-2011, 02:21 AM   #739 (permalink)
Hallo again
I have tryed everything you said. But nothing is changed. I set fuel% on 100%, tank dist on zero, Used tank on zero and when I start driving average consumption goes from 99L/100km and falling down to 3-3,8 L/100km for a 3-4 km driving distance. It is easy to see instant cons showing 6,5 L/100km and average cons shows 4 L/100km and falling.
Anybody had the same problem?
Which program version is tested by you and working well, Maybe program is faulty?
Old 07-15-2011, 02:22 AM   #740 (permalink)
I am using version 191
obd2
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 4 06-01-2015 04:58 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 04:57 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 10:04 PM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
