Old 10-08-2014, 08:58 PM   #91 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Love your craftmanship!
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
The Following User Says Thank You to jedi_sol For This Useful Post:
OG VX (10-09-2014)
Old 10-08-2014, 11:15 PM   #92 (permalink)
ALL UP ON THE INTERWEB!!!
vrmouseyd15b's Avatar
skidmark - super snail - '89 honda civic wagon WAGOVAN
Team "Old SKOOL"
90 day: 30.87 mpg (US)
Pituca - '19 Honda Insight Touring
90 day: 39.34 mpg (US)
I knew it would be sick! Nice man, nice. ..
The Following User Says Thank You to vrmouseyd15b For This Useful Post:
OG VX (10-09-2014)
Old 10-09-2014, 09:48 AM   #93 (permalink)
JDM hypeR mileR
OG VX's Avatar
The OG VX - '92 Honda Civic VX
90 day: 68.64 mpg (US)
Fellas, thanks so much for the support.
I mounted the buttons last night on the blank panel for the power window switch. Also, tested the MPGuino using the USB on the computer. So, far, looks great! The red LED has a hint of amber in it, which for me, is a good thing. A bit of 3M Amber tail lense repair tape will adorn the top of the screen. Should emit a nice amber glow to match the gauges and (soon to be) amber swiches/climate control/radio/etc...
Hope to get the MPGuino and Vacuum installed/mounted/running by the end of the weekend.
"Yesterday as I was going in to the shop, I came upon a recently killed Armadillo in the middle of the road with one front leg sticking up. As I passed over him he "High Fived" my air dam. I thought that showed a great attitude on his part." -The Donkey CRX
Old 10-10-2014, 03:16 PM   #94 (permalink)
JDM hypeR mileR
OG VX's Avatar
All, here’s a few pics to share of the LED headlamps, in case anyone was curious on their output.
I was about to paste all of this onto an LED thread elsewhere (Honda-Tech Lighting Section) and thought I would throw it here in my build thread as well. OEM USDM headlight housings and fogs used.
Low Beam (one LED activated per bulb) + Nokya Hyper Yellow (H3) fog bulbs
Low Beams w/ NO fog lights on:
Hi Beams (two LED’s activated on each bulb)
Old 10-10-2014, 06:40 PM   #95 (permalink)
JDM hypeR mileR
OG VX's Avatar
Update 10/10/2014: Custom MPGuino Housing- Part 3
Since I was out of bondo, and I knew I was down to my last layer or two, I opted to go for the “Gold” Bondo. Good stuff! Seems to sand the same, but the mixing and application processes were much easier/smoother. The product also took longer to set, giving me more time to work it into shape. That was, particularly, helpful with this obscure shape I had to work with.
I had to dremel in a little “notch” inside for the plastic tab on the LCD board just next to the screen.
I then put my focus into drilling some holes. I made a grid-type design on the underside to help with heat dissipation. It is my understanding that the Arduino boards do run a bit hot. I hope that this will help some.
Drilling the holes for the front proved a bit tricky, but I slowly worked the holes with a drill bit until everything fit correctly. The screen now fits snugly and flush. (final hand sanding will cure the wavy-gravey's around the outline of the screen).
The housing for the buttons (formerly the power mirror delete-panel from the dash) is now drilled and they are mounted. Some bondo work and paint is needed, however. I got a bit over-zealous with my dremel while enlarging the holes. I’ll also straighten out the buttons, as they are not all yet perfectly linear either.
More to come. Thanks for eco-tuning in.
The Following 2 Users Say Thank You to OG VX For This Useful Post:
California98Civic (10-11-2014), jedi_sol (10-10-2014)
Old 10-16-2014, 12:12 PM   #96 (permalink)
JDM hypeR mileR
OG VX's Avatar
(Mini) Update 10/16/2014: MPGuino Housing + Install
Getting close on this one. It won't be long now...
California98Civic (10-17-2014), The donkey CRX (10-16-2014)
Old 10-16-2014, 01:38 PM   #97 (permalink)
Looks good.
The Following User Says Thank You to Daox For This Useful Post:
OG VX (10-17-2014)
Old 10-17-2014, 12:20 PM   #98 (permalink)
EG6 - '95 Honda Civic VX
90 day: 50.1 mpg (US)
Clownshoe - '00 BMW Z3 Coupe
90 day: 27.92 mpg (US)
M3 - '95 BMW M3
90 day: 24.39 mpg (US)
M Coupe - '99 BMW M Coupe
90 day: 22.67 mpg (US)
Z3 Coupe - '01 BMW Z3 Coupe
90 day: 26.24 mpg (US)
E90 M3 - '08 BMW M3
90 day: 20.83 mpg (US)
I enjoyed reading your thread! I'm not too far from you (In Charlotte). I have a VX as well, maybe I'll see you on the road! I may send you a PM to help install a mpguino in my beast!
The Following User Says Thank You to KROHN27 For This Useful Post:
OG VX (10-17-2014)
Old 10-17-2014, 04:12 PM   #99 (permalink)
JDM hypeR mileR
OG VX's Avatar
Thank you sir! I checked out your VX in your welcome thread. Man, that VX is CLEAN!
We should put together a VX meet for Charlotte-Metro owners
Old 10-17-2014, 04:20 PM   #100 (permalink)
JDM hypeR mileR
OG VX's Avatar
Mounted. Just have to connect all of the wires.
The Following User Says Thank You to OG VX For This Useful Post:
Fat Charlie (10-20-2014)
