Old 10-17-2014, 04:00 PM   #101 (permalink)
ALL UP ON THE INTERWEB!!!
vrmouseyd15b's Avatar
skidmark - super snail - '89 honda civic wagon WAGOVAN
Team "Old SKOOL"
90 day: 30.87 mpg (US)
Pituca - '19 Honda Insight Touring
90 day: 39.34 mpg (US)
Looks great! What did you decide for the lean burn indicator? Lots of people want one, I'm sure!
Any more questions, don't be bashful, OG.
Keep it up!
Victor
The Following User Says Thank You to vrmouseyd15b For This Useful Post:
OG VX (10-20-2014)
Old 10-17-2014, 06:11 PM   #102 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
That's exceptional. This photo makes it almost look as if it is at a slant, bt I'll bet that is an optical illusion. That's really about as good a mount as anyone will make at home. Very nice, really.
OG VX (10-20-2014)
Old 10-17-2014, 07:45 PM   #103 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
very clean!
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
The Following User Says Thank You to jedi_sol For This Useful Post:
OG VX (10-20-2014)
Old 10-20-2014, 10:59 AM   #104 (permalink)
JDM hypeR mileR
OG VX's Avatar
The OG VX - '92 Honda Civic VX
90 day: 68.64 mpg (US)
Keep it up!
Victor
Thanks bro, and I appreciate all your help through PM's/calls of late. Such network and support on this site!
For the LED light, it's currently tacit. I just needed to get the car back on the road for now. Wire's are rolled up neatly under the dash, until I can either figure out a way to run a Lean-Burn light, or come up with another use for it.
Thaks California98Civic and JediSol. I appreciate your support fellas.
Cali- Yeah, the angle came out slanted down a few degrees once completed... I'm not entirely sure how that happened, as I did "measure twice" throughout the whole process. Seeing as how Bondo has not yet come out with a Viagra-type fix agent, I'm not losing sleep over it though.
"Yesterday as I was going in to the shop, I came upon a recently killed Armadillo in the middle of the road with one front leg sticking up. As I passed over him he "High Fived" my air dam. I thought that showed a great attitude on his part." -The Donkey CRX
Old 10-21-2014, 04:56 AM   #105 (permalink)
I had not seen any MPGuino installations that I liked until now, but that is beautiful!
OG VX (10-21-2014)
Old 10-23-2014, 12:42 PM   #106 (permalink)
JDM hypeR mileR
OG VX's Avatar
Update 10/23/2014: MPGuino Final Install + Initial Impressions + Amber Dash (Cont.)
Hello all, here’s some updates! Install was completed on the MPGuino last weekend. It turned out to be a long weekend, and this project “fought back hard” (ever have one of those?), but we got it done. I won't go into complete details, but lets just say I made an SOS-call out to a fellow EcoModder, after the MPGuino display (once completely mounted and wired) displayed information upside down b/c yours truly mounted it that way. Yeah...
Here’s my son putting in some work, telling me where to find the VSS and Injector junctions within the harness at the ECU.
Here’s a cover that I made out of the vinyl from the back flap of a cheap Walmart binder. It covers up the LCD screen edges that were exposed behind the MPGuino panel opening. Cleans things up a bit, visually-speaking.
Here’s how I coated all of my bulbs to an amber color. This included the AutoMeter Vac gauge (left bulb in the picture; right bulb is a blue one for my F150 gauge), as well as all other dash bulbs, as I used the same translucent Tamiya-brand model paint to re-coat the amber bulbs I purchased from Autozone a couple of weeks back. They were always a pale orange hue, and getting worse daily. Since being re-coated with the Tamiya paint, they now REALLY pop; a nice red-orange hue. I like this paint a lot, as it coats on "thick", even when you do just one coat. I used several, of course, to ensure it lasts as long as possible under daily heat exposure. We’ll see how long it lasts. I just brush painted it on, and let it dry. In the model-kit world, this paint is used to paint tail lights.
I also continued dash work, and used the same translucent Tamiya paint previously mentioned to paint the LCD screen within the dash clock assembly. I simply opened up the clock by prying at the tabs with a small screw driver, painted the screen, let it dry, and re-installed. Voila! “JDM Amber Clock” on the cheap.
Honda-heads, is this amber the correct color, or should I add a layer of translucent red on top as well? It’s a bit more of a “medium orange” hue than I have seen from other DIY “JDM Amber” clocks on the net. Others I have seen appear to be more of a orange-red hue. Which color is more accurate to the original JDM piece?
While I was on the interior-restoration path, I decided to re-do the gauge cluster, as I wasn't happy with the paint I used on the first go around. The original red paint I used was a lacquer-based model paint. It was too dark (more of a wine red) and didn't match well with the red line color of the tachometer and other OEM-red elements on the gauge face. More importantly, the lacquer paint would get “sticky” in hot temps, and the needles were sticking to the posts they rest on when the car is off. I’d have to bang the top of the dash like an old television to get them to “un-stick”. No sir! That ghetto-ness had to go.
Also, the green paint I used did not adhere well to either the gauge face or the needle. It actually retracted, shriveled up, and fell off the fuel needle. So, I went to Wal-Mart and got some Painters pens from their craft section. Man, I'm glad that I did! The colors are excellent. The red I chose is a closer match to OEM red-color found on the gauge faces, and the new neon-green color pops like crazy, and reminds me of the green hue used on the needles and face of the Spoon EK clusters. Pops very well, easy to see at dusk/dawn, and (IMHO) looks sick! Most importantly, proper adhesion is now made on the gauge/needles, and the nice satin-like finish looks both OEM and doesn't create any “sticky situations” on warmer days.
I also OCD-cleaned the interior. Things are starting to really come together inside the car now, I think. Pics below show my completed mirror set up also. I drilled in some set-screws to lock in the mirrors, as they like to fall due to the added weight of the large convex mirrors being taped to them. The small mirrors that come attached to the “Ultimate Blind Spot Mirror” units weren't large enough for my tastes/needs. Actually, the driver’s side worked well, but the passengers side wasn't large enough. I went ahead and “upgraded” both sides for visual-congruence.
And here’s the completed MPGuino button panel. Works great, and is easy to get to/manipulate. I used a red button on the far left, since it’s the one that toggle’s between the different screens on the dislply (Actually, it was initially more of an adaptive decision, as Radio Shack only had 2 black buttons, ).
And here’s the MPGuino in action!
While not the most inspirational stats being displayed in this picture, on the contrary, the device is helping me greatly. It’s a whole new ball game for me now! I have a much more accurate monitor with which to make best decisions on engine rpm vs. gear selection. So many questions I had before are now being answered, and I’m learning more each day about what to do in different driving situations. The possibilities on the road are endless, due to traffic patterns/hills/etc… Now that I have this, I can’t possibly imagine trying to “extreme hypermile” without one. The MPGuino (or ScanGuage) tool is, simply put, a must for hypermiling. The vac gauge is very handy also, and the combo of the two is perfect. Please see my trip meter in the pic above. Iv'e never hit 300 miles before the needle got to the halfway mark before. My best so far (on 87 octane) is about 260 miles before the needle dropped below the halfway point. MPGuino is only giving me about 54 mpg so far for this current tank, but I have not fully calibrated it yet. I suspect (and hope) that number is going to be a bit higher when I refuel a few days from now. I’m hoping to hit close to 60 mpg on this current tank filled with 87 octane gas, with a goal of breaking 65 mpg using 100% E0 gas in the near future...before more intense aero mods are completed.
Given the wind resistance I'm currently fighting (especially in the morning commute), that’s a lofty goal, but I’ll let you guys know how it goes.
This weekend’s build time will focus on a custom safety sign for the rear hatch, and I may possibly dive into some lighter front-end aero work.
As always, thanks for eco-tuning in!
The Following 3 Users Say Thank You to OG VX For This Useful Post:
Fat Charlie (10-27-2014), jedi_sol (10-23-2014), The donkey CRX (10-23-2014)
Old 10-25-2014, 08:28 AM   #107 (permalink)
JDM hypeR mileR
OG VX's Avatar
Update 10/25: Milestone MPG Stat + EcoSafety Sign (Part One)
Yesterday I filled up after my first full tank using the newly-installed MPGuino. I was hoping to hit 60 mpg on 87-octane. I did not. I hit 64.5!! This was a huge surprise. I still can't believe it. I guess since I've now hit my MPG goal for this project...I'll keep on going
OK, now on to this weekends project: I'll refer to it as an EcoSafety sign. Interstate traffic during my commutes is viscous. I'm hoping that having this sign on the hatch will help me and all other pedal-pushers on the road to stay: (1) sane ; (2) alive. My wife is not too thrilled about it's addition, claiming "I will not ride with you!". She may just be lying, and perhaps secretly thinks this sign is kinda sexy. But just in case she if fo-real... as you can see, I've designed the EcoSafety to mount to some magnetic dealer license plate tag holders, so that I can remove it easily when she wants to ride (or in case the cops don't like my sign and it's flashing arrows).
Pics below tell the mock-up I completed this morning. I used a thick plastic see-through sheet, which made quick work of things. The final version, of course, will be made out of a thin sheet metal. It's a great weekend to paint, so I'm fortunate.
Mock-Up
Various materials for this Project:
Final-Shape
Mocked-Up Design Layout
"Dirty" mock-up
Paint for the final panel
I'll continue and post more on the EcoSafety sign as I go.
Also, I'll be using this material I found to make a grille block and fog light covers. It WAS the flimsy floorboard in my hatch. Sorry material for a hatch floorboard, but a perfect material for what I need it for. Easy to cut, yet resilient to impacts and the elements. Alright!
More to come. Thanks for eco-tuning in!
The Following User Says Thank You to OG VX For This Useful Post:
The donkey CRX (10-25-2014)
Old 10-25-2014, 09:28 AM   #108 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Dude that sign is sooooo funny hahahahahah! That is some sick progress your making, not to mention your MPGuino setup, I'm so jealous! Please keep the updates coming!
The Following User Says Thank You to Baltothewolf For This Useful Post:
OG VX (10-25-2014)
Old 10-25-2014, 09:57 AM   #109 (permalink)
Team "Old SKOOL"
Lots cheaper than one of these. ..
Drivemocion Car LED Sign | GadgetsAndGear.com: http://youtu.be/Dam7KVZiWgI
still very cool. Nice work!
OG VX (10-28-2014)
Old 10-29-2014, 12:41 PM   #110 (permalink)
JDM hypeR mileR
OG VX's Avatar
Update 10/29/2014: Sun Visor Delete + Ecool Breeze
Hello all, back here with some more eco-related updates. I didn't get any aero-work started this past weekend, but instead worked on finishing up adding a fan to the interior. I figured I should finish this project asap, while the weather was still warm enough for me to put such a fan to use. It’s now done, and running great! I love it. I’ll call this mod my “Ecool Breeze”. So, follow along and “let me take you to an island of the Ecool breeze”. (Terrible Shaggy pun, younger members likely won’t get it…so, sorry).
I didn't take many process-pics for the fan install, but it involved making a template from cardboard of the existing passenger side visor mounting holes, then transferring the template to cut out of a piece of 1/8" metal bar. I also added holes for the fan mounting base and switch panel to the mounting bar.
I decided to do a visor delete while I was at it, and used the existing visor bases/mounting plastics to incorporate into the fan mount design. Modified OEM pieces now serve as “blanks” for the driver’s side of the car, and offer cleaner mounting points for the fan on the passenger side of the car. The fan wiring runs down the passenger A-Pillar and sneaks into the cigarette lighter connection, for a cleaner look.
Pics:
RustOLeum hammered paint was used for the topcoat on the fan mount.
Here's how I modified OEM visor clips. I used a dremel bit to file them down, then Bondo filled the holes, then sanded, then used some SEM light gray to bring out an OEM-like finish.
For the far left/right visor mounting bases, I filled the center hole where the visor post once ran with an adhesive putty I got at Harbor Freight a while back. Iv'e used this stuff for all kinds of projects. Really cool, as you roll the two parts together like play-doo, then fix it in place, and it dries to a hard and strong finish. It sticks to plastics well. I remembered that it dried to a dull gray color as well. It turns out that the color was nearly a perfect match to my OEM interior, so no paint/bondo was needed. i just filled the holes and smoothed out the tops a little by hand, then let them set to dry, and voila: Fixed and (I feel) very presentable!
For those wondering, I no longer have a use for the drivers side visor. I can’t pull it down anyway due to the mirrors at the sides of the car. Fortunately, the side mirrors are large enough that I can lean and hide from glare behind them on moments of intense sun glare. I also have…wait for it…
sunglasses.
Finished Pics of the new set-up:
I’ll be back soon with pics of the finished EcoSafety sign. It’s about 95% done at this point.
As always, thank so much for EcoTuning in.
