Old 02-13-2010, 04:53 PM   #2951 (permalink)
jackbauer's Avatar
Works great thanks paul! I guess my software will have to be yet another "special build" from now on
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 02-13-2010, 04:57 PM   #2952 (permalink)
PaulH
MPaulHolmes's Avatar
Well you are a special person, Jack! hahahaha.
kits and boards
Old 02-14-2010, 04:08 AM   #2953 (permalink)
jackbauer's Avatar
Could I further press my luck by asking for a 5 second delay between the throttle hitting zero and the pin going low? Just dont want the contactor cycling all the time. Thanks again.
www.evbmw.com
Old 02-14-2010, 05:48 AM   #2954 (permalink)
jackbauer's Avatar
Here's the little control board. Just an npn transistor and a 5v changeover relay. Works great. Might even be useful for other applications.
www.evbmw.com
Old 02-14-2010, 09:18 AM   #2955 (permalink)
PaulH
sure Jack! Did the other modification actually work? I have never actually successfully compiled and then tested anything from the Linux build environment.
kits and boards
Old 02-14-2010, 09:36 AM   #2956 (permalink)
jackbauer's Avatar
Yeh it works great thanks. I'd just like a little delay (say 5 seconds) between throttle going to zero and the pin going low. Just saves wear on the contactor. Also in a failed power section situation I'd rely on the shunt field to stop the motor overspeeding.
www.evbmw.com
Old 02-14-2010, 11:37 AM   #2957 (permalink)
jackbauer's Avatar
Got it Paul works great. Noticed one thing though. I setup a 10sec precharge , switched on , opened the throttle. Precharge expired then it went full throttle! Looks like the high pedal lockout doesnt work during precharge. So potential situation if someone unfamilliar with the car gets in , switches on , floors it "duh , this car dont work!" , precharge expires , contactor closes ..................................
www.evbmw.com
Old 02-14-2010, 12:50 PM   #2958 (permalink)
dave koller's Avatar
Jack
I latch my throttle relay on throttle down and have it go off with clutch, brake (parking brake), over-rpm, and E button - probably doesn't help in your case but I did it as a safety feature.. If you want to adjust the delay (in hardware) use a mosfet on that relay and have it hold for an adjustable delay with a resistor/Cap on the gate..
OR-- LOL - have Paul zip you over a new Hex file ( I assume that's what is going on) --
Old 02-14-2010, 02:11 PM   #2959 (permalink)
jackbauer's Avatar
Dave , yeh paul has sent me over a new hex file. The purpose of this setup is not to control the main contactor but the power to the shunt field section of my compound motor. It takes about 4 amps at 72v so no point having it on when sitting in traffic etc. I needed a delay on the turn off to stop the contactor jumping in and out when using light throttle and in the event of a controller failure the shunt field will stop the motor from overspeeding and give me a chance to turn the key off.
www.evbmw.com
Old 02-14-2010, 02:50 PM   #2960 (permalink)
LOL I gotta look at the C code for that (if it is somewhere) - nice point Jack - I have done a similar lockout in "logic" on my board (no processor) BUT made me double check - guess my audio feedback could say " take your foot off the gas DUMMY -"...
Dave ...
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
