Old 03-11-2010, 02:39 AM   #3131 (permalink)
jackbauer's Avatar
Hey I sometimes have to stay up a whole "24" hours
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 03-11-2010, 02:47 AM   #3132 (permalink)
PaulH
MPaulHolmes's Avatar
hahahahahahahaha!
kits and boards
Old 03-11-2010, 04:57 AM   #3133 (permalink)
Originally Posted by adamj12b View Post
Hey Everybody,
So I finally got a chance to install my new driver boards on my controller the other night. I had to take the whole controller apart inorder to make the necessary modifications for them to work. The controller was designed from the beginning for a driver board, but after the first one I found some problems and changed the board to improve it. Well, Im super tired and cant really think of what to type, so here is a bunch of pictures.
-Adam
Nice! There's nothing like a great looking power section to give me the Warm and Fuzzies.
John M.
Owner
CamLight Systems
Old 03-11-2010, 04:58 AM   #3134 (permalink)
Nope, not buying that for a second...you get to nap during the commercials.
John M.
Owner
CamLight Systems
Old 03-11-2010, 05:15 AM   #3135 (permalink)
Request
HY all
do you know from where can i buy 2 aluminium heatspreaders
300mm lenght
100mm height
20-30 mm deep
thanks
my contoler is almost ready
thanks Paul & Adam
Old 03-11-2010, 07:57 AM   #3136 (permalink)
Hello great job you have here, My name is Ivailo Minikov from East Europe country Bulgaria ,Sofia city
I have some EV projects two bicycles and one BMW E36 here i have some info about them: wwwDOTevalbumDOTcom/3027
Now i want to make controller for series starter dc motor. I am using starter motor for a second electric bicycle and that thing runs on 12 volts with one button and one relay .
Yesterday i spend many hours building a dc controller.
I am not using PIC because i can't program it . I am using old chip with build in shim modulator. TL494
and mosfet driver tc4422
I have some success with one 400w dc motor with permanent magnets i drive it well watching in my oscilloscope. I test it on 30khz and it runs well.
After that i try it on starter dc motor and the schottky diode that i am using start smoking and after 3-4 seconds burned After that and four irf540 too and tc4422 driver too you know how it is .
Now i made some tests with lower frequency maybe 4khz here is video : wwwDOTyoutubeDOTcom/watch?v=5tmLC2JFfeE
I want to ask you what frequency is recommended for series dc motors ? Thank you for your time
Old 03-11-2010, 08:08 AM   #3137 (permalink)
Hi Ivailo,
If programming a pic is your only thing preventing you from using it, I am sure someone on this list could send you a programmed pic for a small fee. Paul has shipped my kit and can't wait to start building it and getting the rest of the car ready for it.
Greg
Old 03-11-2010, 08:21 AM   #3138 (permalink)
Originally Posted by Greg Fordyce View Post
Hi Ivailo,
Greg
Hi Greg that will be good solution too, it is nice to know people like you
Old 03-11-2010, 08:27 AM   #3139 (permalink)
ReVolt Enthusiast
Good Work !!!
adamj12b - So I finally got a chance to install my new driver boards on my controller the other night. I had to take the whole controller apart inorder to make the necessary modifications for them to work. The controller was designed from the beginning for a driver board, but after the first one I found some problems and changed the board to improve it.
Hi Adam,
It’s nice to see your re-packaged ReVolt controller come together, I still really like that board to heatsink sandwich design !!!
It would have been nice to see your SMT ReVolt controller on top of it too …….
I would like to see others forum members take on and share ReVolt controller projects like yourself. Everyones open source ideas and input only make for a better ReVolt !
I'm still working on my re-packaged variation of the "Rev C-D" ReVolt and will share more after I nail down the new layout. I'm moving away from a multilayer busbar to a "heavy copper PCB" power board design (1000A?).
I hope that future ReVolt schematics and firmware will continued to be shared here in this forum for those of us that want to re-package our own ReVolts.
Keep up the good work,
-Mark
Old 03-11-2010, 08:36 AM   #3140 (permalink)
EVVette - '71 Chevy Corvette Coupe
-Mark
I know, I know......
I ran into some troubles with the 2 control boards that I showed being reflowed a few weeks back. Turns out that some of the power traces to the micro are messed up. I could fix them, but there are some other things that are really bugging me about it. Like 1: Make sure you know what parts you are going to use before you place the pads!!!!!! Trying to find parts with the right specs to fit pads can be almost impossible. I also used some surface mount stuff that is cheeper in a different package....Like the Vreg....If I used a D2PAK instead of a Dpack, I could knock off like $3 from 1 chip!!! so im going a light redesign to handle the new more economical and easier to obtain parts, then will be making that one. I also found a few other little things that really ticked me off. Like a resistor half under an IC....
I just picked up some stuff to chemically etch some boards. Thought I would give it a try. I will use the new control board as a test.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
