Old 12-14-2011, 12:36 AM   #5301 (permalink)
PaulH
MPaulHolmes's Avatar
Originally Posted by amino View Post
I have been trying to trace the fault. With the controller on the bench again, I checked the voltage at pin 2 of the optoisolator U9, and it reads 4.91V on switching on and 3.75V after precharge. There is no change at pin 4 though.
OK, can you see what the voltage is on each side of R23 relative to ground before and after precharge?
kits and boards
Old 12-14-2011, 12:46 AM   #5302 (permalink)
PaulH
Actually I think that's fine. 3.75v down from 4.91v sounds OK, since it's just going to be a voltage drop from the diode. It sounds like the optocoupler isn't working for some reason.
kits and boards
Old 12-14-2011, 12:58 AM   #5303 (permalink)
EV DIYer
I am getting 4.91vbefore and 0.22v on the U3 side
and on the U9 side of R23, 4.91v before and 3.75v after precharge .
At pin 4 and now it shows 11.09v before and 7.63v after precharge.
Will I need to get the exact replacement optocoupler, or can I use a substitute?
Amin
Old 12-14-2011, 01:19 AM   #5304 (permalink)
PaulH
I can send you another one, but it might be quicker for you to stick in another one. Here are some of the specs for it:
HCPL-817-000E Avago Technologies Transistor Output Optocouplers
So I guess something that's similar to that.
These are very good:
FOD817D300W Fairchild Semiconductor Transistor Output Optocouplers
Do you want me to mail you one of each, straight from Mouser?
If you short from Pin 4 to Pin 3 on U9 (maybe with an alligator clip or something), does the contactor close? Be careful not to do this before the precharge has happened. I would verify that the capacitors are full first. If the contactor closes, then Q1 is good.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
amino (12-14-2011)
Old 12-14-2011, 01:45 AM   #5305 (permalink)
EV DIYer
Yes, the contactor does close when I short Pin 4 to Pin 3 on U9 (with a pencil lead point). I have the controller on the bench with just the 12 volt supply going to it. It is on a board with the contactor and fuse as an assembly, making it easy to connect and remove from the car.
I will let you know if i cannot find a suitable optocoupler here.
Amin
Old 12-14-2011, 02:06 AM   #5306 (permalink)
PaulH
I"m just curious why it's not working. Collector to emitter voltage maximum is 35 volts, but I think those fail shorted. It might still work, but maybe it just has a horribly crappy current transfer ratio?
kits and boards
Old 12-14-2011, 02:30 AM   #5307 (permalink)
EV DIYer
Paul, My knowledge is somewhat limited when it comes to optocouplers and semiconductors in general. Maybe the heat from soldering iron affected it?
Amin
Old 12-14-2011, 02:40 AM   #5308 (permalink)
PaulH
Nah... Rule #1. Blame someone else when it doesn't work.
New controller soldering a success!!!:
Oh no! They are going to fall on the ground! hahaha.
Each of these would take about 30 bashes with a hammer and flathead screwdriver to remove:
That was just the diode bar. Tomorrow is the MOSFET bar! The process is easy now that I have it down.
kits and boards
The Following 2 Users Say Thank You to MPaulHolmes For This Useful Post:
deodeo (04-22-2012), mpgmike (01-21-2022)
Old 12-14-2011, 04:05 AM   #5309 (permalink)
EV Connoisseur
Paul, are those glued on?
Old 12-14-2011, 04:09 AM   #5310 (permalink)
EV Connoisseur
Soldered right.. but I don't see any solder?
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
