Old 11-18-2014, 08:53 PM   #6931 (permalink)
PaulH
MPaulHolmes's Avatar
I ran into a similar problem with programming the AC controller. It turned out that the colorful ribbon cable wasn't allowing it to be programmed correctly. Too dang long. Once I switched to a 6 wire shielded cable, everything was OK. It did work the few times I tried it with yours, but maybe it's one of those hit-and-miss things. Sometimes works and sometimes doesn't. I actually just bought some shielded 6 wire cable. I could mail you some. I don't have any 5 or 6 pin connectors though. I'd need to order that. In the meantime, it's extremely annoying, but you could take the enclosure off, and plug the pickit 3 right in to the 6 prongs with no cable. That's much more reliable because there's no cable involved.
I'll still looking for what could be causing the problem. I haven't found anything yet. I'm going to send you a simplified hex file, which doesn't use the EEProm at all. Just your programmed settings hardwired in. You can try programming that onto the chip using the ribbon cable. Worst case, you may have to remove the stupid top and plug the pickit 3 right in. dang it!!!
edit: I just sent a new hex file that skips reading from the EEProm, and just loads a default value in. BEfore, it would read from the EEProm, and if there wasn't a valid setting, it would load a default. But who knows. Maybe there was some left over valid programmed values that were messed up. So, let's avoid that difficulty at the moment, and just load defaults that I know are good. I hope this works!!
kits and boards
Old 11-18-2014, 09:11 PM   #6932 (permalink)
Hi Paul
I think I'm being a numpty
Can you send me a list of the steps I need to take in updating the PiCkit
I think its
Set device
Import your program
- it says successful
connect to device
- it asks about 5v and then target detected device ID revision = 1004
Then (and I didn't do this before) hit the "program" button
it says - programming complete
Pass Count 1
I haven't tested it in this state except to try the RTD - which operates, communicates
But does not seem to find anything
If I then press the "Verify" button
I get
Verify Failed
Can you lead me through what I should be doing - please
Old 11-18-2014, 09:48 PM   #6933 (permalink)
PaulH
1. Set device
2. Import your program
3. Programmer->Select Programmer->6 PICkit 3
4. Turn on the 12v power, which does the following:
connect to device
5. Programmer->Erase Flash Device
6. Programmer->Program
7. Programmer->Verify
Try that! Maybe it needed to be erased first?
kits and boards
Old 11-18-2014, 10:00 PM   #6934 (permalink)
Hi Paul
Not done the erase thing yet
Put your latest program in
Now the car could climb the slope!
Felt really lively - I was careful with the throttle until I got down the hill and onto tarmac
Then I throttled
Quick surge and then it cut out - no response
I shut it all the way down
Back on - power again
But as soon as I hit the throttle - shutdown
Being New Zealand in the spring it was now hailing!
It drove back up the hill - a really steep gravel hill - with me being careful with the throttle
Not sure how much current but I saw 100 battery amps at one stage
Feels like some sort of over-current shutdown
The Following User Says Thank You to duncan For This Useful Post:
MPaulHolmes (11-18-2014)
Old 11-18-2014, 10:25 PM   #6935 (permalink)
PaulH
Crap, I wonder what I had the hardware overcurrent set to. There's a little cube shaped pot on the control board. I can't remember how far I have it twisted clockwise. Fully Clockwise should cause a hardware overcurrent at 600amp per IGBT. It's on the left side of the board, and is blue. It needs a small phillips screw driver head, or a fingernail?
I would download realterm. I don't think this controller is compatible with RTD Explorer. Get that here:
RealTerm: Serial/TCP Terminal | SourceForge.net
Then, set it to 8 data bits, No parity bit, and 1 stop bit. Also, 19.2kbps. It will display the text from the controller's serial output. Then you can see what fault is happening. It probably is the hardware overcurrent. If the small blue pot is already twisted fully clockwise, then we probably need to tune the PI loop. It is likely overshooting right now if the blue pot is fully clockwise already.
What voltage are you running?
We can also clear the hardware overcurrent at like 1kHz or something, but it shouldn't be tripping at all. Fully clockwise is 1800 motor amps for hardware overcurrent.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
duncan (11-19-2014)
Old 11-19-2014, 12:27 AM   #6936 (permalink)
Hi Paul
I turned the wee blue cube thing clockwise
It's magic!
The tires slip on take off - then grip
I think I could even use the 1200amps -
But that's for later,
I'm hitting up to about 800 battery amps now!
Great!
There is a motorsport event in Christchurch on the 30th November
Evolocity » eMotorsport
I'm entered - now I'm good to go!
Thanks for all of the help - now lets go and see if I can keep up with a Tesla
I'm using Headways - 16Ah (nominally but they are actually a good bit less)
With four strings of 40 cells
So about 130v
They are 10C continous - 640 amps
and 15C burst - 960 amps
But they do saaaag
The Following 3 Users Say Thank You to duncan For This Useful Post:
MPaulHolmes (11-19-2014), mpgmike (01-24-2022), thingstodo (11-24-2014)
Old 11-19-2014, 12:34 AM   #6937 (permalink)
PaulH
Yahoo!!!!!!!
I can send you 1200amp code tonight if you want. I will do that. And you can use it if you want.
kits and boards
duncan (11-19-2014)
Old 11-24-2014, 03:11 AM   #6938 (permalink)
Hi Paul
Been driving the Device - its great fun - feels very lively without trying to kill me
I notice a hiss/whistle - I think its from the controller although it "sounds" like its coming from behind me
Not at all a nuisance in fact it's useful as it seems to be proportional to current
My speed signal to the Cycle Analyst seems to have gone again - I will have to fix it after the weekend sprints
I will try and mount my GPS somewhere - just in case I overspeed the motor
Anyway
Thanks again for a real fun controller - I will keep you guys updated about how it is doing
jedsmd (11-24-2014), MPaulHolmes (11-24-2014), thingstodo (11-24-2014)
Old 11-24-2014, 04:36 AM   #6939 (permalink)
PaulH
hello! That's great to hear. The hissing is the spread spectrum switching so there won't be a piercing 8khz tone. Will the races be filmed? I'm curious to see you in action!
kits and boards
duncan (11-24-2014)
Old 11-24-2014, 09:57 PM   #6940 (permalink)
Paul
What frequency did the old 500amp controller use?
I will see if I can get a film of me missing the apexes and generally doing a terrible lap
Not deliberately - I'm just not that good a driver
The guy I used to mechanic for could go much faster than me - even in my car!
MPaulHolmes (11-30-2014)
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
Copyright ©2000 - 2022, vBulletin Solutions Inc.
