Old 03-29-2010, 06:50 PM   #381 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Originally Posted by vpoppv View Post
Ok, I can now confirm that lead/acid batteries can/do explode.....
Wash your hands/face/body, get the baking soda, THEN grab your camera so we all can see!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 03-30-2010, 05:40 PM   #382 (permalink)
The $500 Electric Car
vpoppv's Avatar
Ok, so I had one battery that was showing pretty low voltage after commute, like in the 9 volts range, so I knew it was having some trouble. So Yesterday I am on my way to work, and I get most of the way there when I heard a VERY loud "pop". I immediately knew what it was:
Old 03-30-2010, 09:58 PM   #383 (permalink)
order99's Avatar
Um.....OUCH.
Old 03-30-2010, 10:46 PM   #384 (permalink)
Are those cells bone dry!?!?!? Wow, that is what heck of a boom. Did you have to tow it home, or did you just bypass the battery and continue?
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
Old 04-01-2010, 12:00 PM   #385 (permalink)
vpoppv's Avatar
Yes, big boom. Tow Geo and tow rope to get it home. I think I'll put the alum battery back in to replace the exploded one....
Old 04-01-2010, 10:19 PM   #386 (permalink)
90 day: 51.82 mpg (US)
Wow. What do you think happened?
Cell reversal & overheating?
Old 04-02-2010, 12:49 AM   #387 (permalink)
vpoppv's Avatar
Yeah, I'll go with that.....
I was really pushing my luck with that battery as it was and am not at all surprised it happened. I am actually pretty lucky that the one I converted to alum didn't do that before the conversion: it was showing way too low a voltage after commute as well. This gives me even more incentive to relocate the 2 batteries in the trunk outside passenger compartment.
Old 04-02-2010, 08:59 AM   #388 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
My car uses gel cells that are inside the passenger compartment, but sunk below the back seat. (Where the gas tank was.)
That is then covered with 3/4" plywood with carpet over that.
The one time I accidentaly shorted 144V, I was glad that there was that chunk of plywood between me and the battery terminal.
My YouTube Videos
Old 04-03-2010, 10:42 AM   #389 (permalink)
Wow. Well, before I got the battery pack monitor, I reversed cells in a couple of batteries (2 or maybe 3).
When reversal happens, I believe you're effectively charging that cell at whatever amperage you're drawing from the pack at the moment. (For me, that could be anywhere from typically 75-200+ amps!) Which means that battery is going to get awfully warm, awfully quick plus it'll likely be gassing like crazy and building pressure in the case. POW! :O
Old 04-03-2010, 09:11 PM   #390 (permalink)
vpoppv's Avatar
Interview with the battery that popped: up close and personal....
Geo Metro convertible / Kubota diesel engine conversion (driving!) kimer6 EcoModding Central 118 07-01-2013 04:21 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Planning Project Eco-Z seanof30306 EcoModding Central 20 08-24-2009 10:00 PM
Metro Hoarding 101 - also: Metro pickup trucks! Cowspots Introductions 28 04-14-2008 07:26 PM
