Old 12-17-2009, 11:29 PM   #41 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Honda Accord LX
90 day: 35.57 mpg (US)
You forgot to keep reading to the next line line that mentioned epoxy mounting plus adding a pad of (ferrous) metal to the rim.
you're right. i was like, all hung-up on caulk. but not glue.
single person car thread
Old 12-17-2009, 11:32 PM   #42 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Epoxy is not glue, my friend. I feel like there's a negative tone to your posts, as well.
Just because someone doesn't like your idea, doesn't mean you should be offended, if that's the case.
Do you have any idea how many times people have shot down something I had to say? It doesn't affect me because it's their project. Let him do it the way he wants. The only thing you can hope to do is provide input and expect that someday, someone will see it your way.
If I'm reading your posts incorrectly, please, by all means, let me know.
Old 12-17-2009, 11:46 PM   #43 (permalink)
epic stock master
luvit's Avatar
no sweat, christ. i'm not bothered at all. d: i can see some of my comments could appear terse, but i suppose i could add a few additional key strokes to show i'm smiling.
i don't want to affect any moral. (:
EDIT: ah, the epoxy comment was about caulk being calle glue, not me calling epoxy glue.
Old 12-17-2009, 11:53 PM   #44 (permalink)
Like I said, if I was reading into it too far, I apologize. We just like to keep it civil here, ya know?
Old 01-11-2010, 08:11 PM   #45 (permalink)
15" Volvo wheel
+ 16" pizza pan
= perfect fit
Now just need to drill a hole for the valve stem and figure out the way to mount it. I'm thinking clips that stick between the rim and the tire like wheel weights.
The Following 2 Users Say Thank You to tjts1 For This Useful Post:
fusion210 (04-18-2011), NeilBlanchard (04-06-2010)
Old 01-11-2010, 08:19 PM   #46 (permalink)
epic stock master
luvit's Avatar
those look nice. don't drill any holes, other than the valve stem.
you may have to bend your own clips... or use another substance.
Old 01-11-2010, 08:21 PM   #47 (permalink)
I'm actually pressing in the pizza pan against the valve stem to keep it in place. The valve stem is too long. I have to drill the hole plus I want easy access to check tire pressure. It'll be the size of a dime.
Old 01-11-2010, 08:23 PM   #48 (permalink)
epic stock master
luvit's Avatar
yeah, i agree. you need THAT hole.
Edit: or is it, you NEED that hole.
Old 01-11-2010, 08:31 PM   #49 (permalink)
grow up
Old 01-11-2010, 09:41 PM   #50 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
hey that guitarguy could you drill holes thru your allow rims and thrubolt the pan possibly using spacers of correct depth so as to not distort the pan when tightened? maybe do 4 at midpoint or 6 closer to the edges, it would only have a small screwhead or washer showing on the pan side, you could mount nuts on the innerside of the rim with epoxy? maybe wont work just theowin it out there.
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
Where to get a 15" stainless or aluminum pizza pan? Chris D. DIY / How-to 12 12-14-2009 09:58 PM
Pizza pan wheel covers - smooth or perforated? jabb Aerodynamics 5 06-23-2009 09:01 PM
pizza pan - dish in or out? lightning Aerodynamics 14 06-07-2009 12:26 AM
Pruis Pizza Pan Hub Caps.... justpassntime Aerodynamics 1 07-14-2008 09:55 AM
