Old 07-24-2019, 06:34 PM   #91 (permalink)
Ecomodding Apprentice
The mirror monitors are each side of the main display. I also made some isolator swiches on a small panel, including the horn. Last year it had a spell of the alarm going off. The nearside camera is in the boot. They weigh 580g including cables
...I tidy cables sometime
Old 07-24-2019, 06:40 PM   #92 (permalink)
Thanks, I would say buy woven glass first. Here you can buy 600g for £3 a metre so its not such a loss. The sun, heat and just the stuff going off fairy all effect wether it goes off to quick or in 3 weeks. Keep trying and if it annoys you go back to it the next day
(fun drive thing) I've ordered wheels and tyres to reduce the wheel rolling size by 118mm..just for race gags. Although I may have to make arches so it does'nt look too silly..
More work..
Old 07-27-2019, 06:13 AM   #93 (permalink)
Initially I didn't buy new wheels for speed, they're 3.1kg's lighter per wheel (inc tyre) so will save a bit on fuel. The angular momentum weights are a small with the offset, for me anyway
Old 07-27-2019, 06:54 AM   #94 (permalink)
It took a day or so to get used to the monitor mirrors but they do cover blind spots and save time when driving. Once the bumper is redesigned to reduce the frontal area I'll do a mpg check (may be winter then though).
Old 07-27-2019, 07:15 AM   #95 (permalink)
Originally Posted by mpg_numbers_guy View Post
What wheels do you have on the Prius? They look like the larger, heavier Touring wheels. You could easily save a few pounds there by switching over to the lighter 15" alloys found on most Prii. IIRC they 15s are 14lbs each, and the Touring are somewhere between 17 and 20 lbs each.
Thanks numbers guy, you were right, they were the touring wheels
Old 07-27-2019, 07:23 AM   #96 (permalink)
Two of the new ones arrived today
Weirdly the tyres weighed more..
The Following User Says Thank You to Nathan jones For This Useful Post:
TexasCotton (05-10-2020)
Old 08-03-2019, 11:55 AM   #97 (permalink)
I weighed twice and the tyres are 6kg and the wheels 4.8. I've also ordered some more sweet stuff
Old 08-03-2019, 12:05 PM   #98 (permalink)
I don't have time to make the carbon one this year so bodged the original for the time being. Increased the rake of the centre section by 20°
ID:	26625   Click image for larger version
ID:	26626   Click image for larger version
Old 08-03-2019, 12:07 PM   #99 (permalink)
It definitely rolls easier and accelerates quicker so will see
Old 08-06-2019, 12:59 PM   #100 (permalink)
Todays change with a few Ah to spare in winter
