Old 07-05-2012, 02:08 AM   This thread is in the EcoModder Project Library | #1 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Project: The Electric Booger (budget EV conversion - '92 Mazda MX-3)
It has officially begun. Today I commandeered the wife's parking spot in the garage to officially begin ripping and tearing.
To clear things up, it is a 1992 Mazda MX-3 Precidia. Booger green. The plan is to build an ultra-low budget EV, using cheapness to my advantage. Much inspiration from the ForkenSwift and ElectroMetro:
http://ecomodder.com/forum/showthrea...nswift-33.html
http://ecomodder.com/forum/showthrea...hread-848.html
For the main bits so far, I have a 72V SePex motor (6.5"X18"), Alltrax 72V (450A) controller and 13 free lead acid battery cores from work, among other things of course.
My parts collecting thread is here: http://ecomodder.com/forum/showthrea...gun-19957.html
My conversion blog is here: Project: Electric Booger
Can you count the missing pieces so far?
With a baby due in a few weeks and my obsession with motorcycling (and the currently beautiful weather these days), it may be a slow go, but I will be sure to post here. I owe it to the EVers in this forum that provided so much inspiration.
EDIT
Here are links to highlights of this thread
Motor/Transmission adapter complete:
http://ecomodder.com/forum/showthrea...tml#post328077
Motor/Transmission installed, front battery racks:
http://ecomodder.com/forum/showthrea...tml#post331955
Rear battery racks:
http://ecomodder.com/forum/showthrea...tml#post332398
Heater:
http://ecomodder.com/forum/showthrea...tml#post332824
First commute in the Electric Booger:
http://ecomodder.com/forum/showthrea...tml#post334612
Commuting to work video:
http://ecomodder.com/forum/showthrea...tml#post337316
New Battery Pack:
http://ecomodder.com/forum/showthrea...tml#post342281
PWM field controller installed:
http://ecomodder.com/forum/showthrea...tml#post342660
Final charging solution:
http://ecomodder.com/forum/showthrea...tml#post350615
TO DO List after one year:
http://ecomodder.com/forum/showthrea...tml#post381386
The Following 2 Users Say Thank You to mechman600 For This Useful Post:
Cd (10-15-2012), Cobb (09-16-2012)
Old 07-05-2012, 07:17 AM   #2 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Good luck with the build !
Old 07-05-2012, 08:07 AM   #3 (permalink)
3n3rgystar's Avatar
Silver Bullet - '92 Nissan Sentra XE
90 day: 37.59 mpg (US)
LOL, nice name and you already got alot parts ahead in the game!
Old 07-12-2012, 02:21 AM   #4 (permalink)
mechman600's Avatar
The ICE is out.
I thought I would need to borrow an engine lift, but it turns out this one goes out through the bottom. Do you think my car lift would be safety approved?
Didn't think so.
Old 07-12-2012, 07:03 PM   #5 (permalink)
Grasshopper - '11 Ford Fiesta SES
Team Ford
90 day: 50.37 mpg (US)
Feejer - '09 Yamaha FJR1300 AE
Motorcycle
90 day: 42.73 mpg (US)
OSHA is a small town in Wisconsin.
Old 07-12-2012, 10:44 PM   #6 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
4x4s are rated I think. it also helps to have a large set of wrenches
Old 07-13-2012, 11:45 AM   #7 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Yikes! Don't get underneath that, even with the engine out it will hurt if it falls on you. Good luck with the build.
I'm not coasting, I'm shifting slowly.
Old 07-18-2012, 11:50 PM   #8 (permalink)
mechman600's Avatar
The other day I hauled the transmission, electric motor and chunk of aluminum to work, where the mating of the motor and transmission will take place. The transmission was absolutely filthy from an engine oil leak and took a good 15 minutes of steam cleaning to get it spotless.
Today I started work on adapting everything together. First off, I am mating the transmission to the keyed shaft side of the motor. Originally this motor was coupled on the opposite end where there is still a gear on the end of the shaft. Unfortunately, the opposite end (the end I want to couple to) has only three 5/16" threaded holes to mount the motor. You can see the three tiny holes around the edge of the motor face.
Not strong enough. I usually prefer overkill. So today I performed some precise measurements and drilled three 21/64" holes into [what I figured was] the thickest part of the face approximately 5/8" deep. Turns out I was right, as I did not go through the motor face anywhere (and get aluminum filings inside the motor). I tapped the holes 10mmX1.5 and made up three short studs.
Studs are the strongest when torquing into aluminum. I will Loctite the studs into the motor face and torque it up to the adapter plate with nuts. Metal on metal instead of torquing into aluminum.
Old 07-18-2012, 11:57 PM   #9 (permalink)
mechman600's Avatar
Yeah, the only thing I am missing is a proper vacuum pump system for the brakes and the potentiometer for the throttle.
Anybody want to donate parts? HA!
Old 07-23-2012, 02:23 AM   #10 (permalink)
mechman600's Avatar
Well, three days ago my wife gave birth to our second child, another girl. So a week off work for me, helping around the house, keeping things under control (as much as possible, anyway....). Surprisingly enough, I have been able to get into the garage to tear apart the Booger some more.
First off, the exhaust system: gone. That was easy. Like....five minutes. A few bolts and a bunch of rubber hangers. That's it.
Secondly, the gas tank: gone. Less easy. But it is official that this car will never ever consume petroleum again. No turning back now.
My boss is building a Miata powered Caterham from scratch and wants the fuel pump, so that will be my first parts sale from this thing, even if it's only for a box of beer. Unfortunately the engine has 280K km on it, so I doubt there will be any takers on that.
