Old 09-06-2009, 12:46 PM   #231 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
The 90-91 Cluster hood is a bit taller, rounder.. I'll see if I have one.
Old 09-06-2009, 12:50 PM   #232 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Thanks for the tips. I'm sure I'll be fine. I'll complain about what I do wrong when I have the welder.
Also, the CRX is a 91, so I already have the rounded hood. The Insight cluster is just taller than the previous integra cluster I was using.
Old 09-06-2009, 12:53 PM   #233 (permalink)
K, I won't look then... I might have a DelSol hood, if you want me to check for that...
Old 09-06-2009, 12:54 PM   #234 (permalink)
Dartmouth 2010
SVOboy's Avatar
The del slow hood won't fit anyway, eh?
Old 09-06-2009, 12:56 PM   #235 (permalink)
Originally Posted by SVOboy View Post
The Insight's engine won't fit anyway, eh?
BANG! Just blew your mind....
It's amazing what can be made to work, especially when it's free, ain't it?
I'll check while I'm here at my Father's house, maybe I got it, maybe I don't.
Old 09-06-2009, 01:02 PM   #236 (permalink)
Dartmouth 2010
SVOboy's Avatar
Your lack of faith disturbs me
Old 09-06-2009, 01:15 PM   #237 (permalink)
NO, sir, not a lack of faith, just a joke.
Before you started, while you were doing research, you probably (I would imagine) thought to yourself: "How in the hell is that thing going to fit in there?"
Just like many before you thought the same, when doing first the B-swap, then the H-swap, then the K-swap, and, most recently, the J-swap.
Everytime, noone thought it would work, but some guy was out there in his shop figuring out WHY it wouldn't work, and MAKING it work...
Enter - You. You're that guy. I'm just not sure how, if you're going to do this, you could let yourself believe that the wrong cluster hood won't fit on your car. :P
Old 09-06-2009, 01:16 PM   #238 (permalink)
Have you tried mounting the gauge cluster without the hood for now? Then make a hood for it later, after you've done the hard stuff...
Old 09-06-2009, 01:22 PM   #239 (permalink)
Dartmouth 2010
SVOboy's Avatar
That's the plan. I'll probably be driving around with no dash and a cluster ziptied to the steering column for a while.
I thought you meant the hood, not the cluster hood
Furthermore, based on the del sol cluster I own, I don't think the hood will help. I'll make due. Anyway, it might work out perfectly if robert smalls has a good answer for me.
Old 09-06-2009, 02:31 PM   #240 (permalink)
Dartmouth 2010
SVOboy's Avatar
How much paint do you think it'll take to do the engine bay?
Also, there was a place online I've seen to get mixed paint for the car, but I can't find it now. Anyone know what I'm thinking of?
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Project: Zombie Insight (2000 Honda) RobertSmalls Hybrids 191 03-03-2012 06:35 PM
Project: Dream CRX SVOboy EcoModding Central 118 09-19-2011 01:42 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
