Old 05-23-2021, 01:50 PM   #781 (permalink)
If you're speaking of the trailer, it's to load bikes. Did you mean the Catalina?
https://i.pinimg.com/474x/b1/fe/fb/b...-the-palms.jpg
Old 05-23-2021, 06:34 PM   #782 (permalink)
No, I meant the Dornier Do-J Wal flying boat. The first commercial aircraft registered in Brazil was one of such type, christened Atlântico. It was built in 1925, incorporated into Varig in 1927 and sold for scrap in 1933. One of its propellers used to be stored at the defunct Varig Museum in Porto Alegre, but its whereabouts are unknown after the bankruptcy of Varig, even though some old engines from other aircraft have been displayed in the same place a DC-3 which used to be operated by Varig is also displayed.
freebeard (05-23-2021)
Old 05-28-2021, 08:38 AM   #783 (permalink)
Random TRANSPORTATION pictures - Page 2482 - Pelican Parts Forums
Old 05-28-2021, 10:11 PM   #784 (permalink)
Would be nice to test-drive it.
Old 06-03-2021, 03:29 AM   #785 (permalink)
Donald J Trump 8/21/21
Disclaimer...
But...
I play one on the internet.
Old 06-03-2021, 04:20 PM   #786 (permalink)
I like it. It has a battle jitney air to it.
Here's an oddity. Could be applied to a car (aerial antenna).
https://duckduckgo.com/?q=scruton+strake
I found it in a story on the Rio-Antirrio Bridge
Old 06-03-2021, 04:42 PM   #787 (permalink)
Looks quite like a croaker.
Old 06-07-2021, 01:09 AM   #788 (permalink)
My Chevy S10 pickup truck has a radio antenna with Helical Strakes.
I think it's aftermarket, was there when I bought the used truck ten years ago.
I've always wondered about it, will take a photo later and see if it actually qualifies.
Old 06-07-2021, 02:35 AM   #789 (permalink)
That is interesting but I didn't really understand this bit from the linked wiki article:
For maximum effectiveness in suppression of vortices caused by air flow, each fin or strake should have a height of about 10 percent of the cylinder diameter. The pitch of each fin should be approximately 5 times the cylinder diameter.
What exactly do "height" and "pitch" mean here?
I can guess that pitch means the vertical difference between 2 bits of the fin, but them what is the height? Do they mean the width of the fin, measured radially from the outside edge of the central cylinder to the outer edge of the fin?
Maybe it is the way my mind works, or maybe it is my total lack of engineering knowledge, but to me the article would be much easier to understand if it included a diagram to show these measurements.
Old 06-07-2021, 03:00 AM   #790 (permalink)
duckduckgo.com/?q=scruton+strake&iax=images&ia=images
