Old 01-14-2013, 05:50 PM   #81 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Get all of your bushings fixed before attempting an alignment. That's probably what's throwing your camber out. Depending on how much you decide to replace, it might be wise to get adjustable toe on the rears and adjustable camber in the front.
Might be of use, but my car sits unevenly after I lower it off my jack, but levels out once I've driven it. I think my dampers might cause this as they're super stiff.
Old 01-14-2013, 08:35 PM   #82 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
An Integra suspension will bolt in to the civic.
http://minneapolis.craigslist.org/ra...496374807.html
- Tony
Old 01-15-2013, 11:39 AM   #83 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
I do intend to do suspension work before going in again. I didn't notice how much stuff was worn out or broken. I will collect control arms, bushings etc. and put them in when I can get my hands on some coilovers. Will look for the adjustable ones. Is there any affordable brand I should go for, or just Ebay it?
civic parts
Going to focus on the bushings now, and once that's taken care of, start saving for coils. I don't think it's worth it to throw money I don't have on another set of stock suspension. At least until I can count the spring coils and see why it's leaning.
Old 01-19-2013, 07:53 PM   #84 (permalink)
Sven7's Avatar
Picked up my new HX wheels today! Weighed them several times at 10lbs. Should make a noticeable difference in driving.
Also, due to recent events I will be be doing much more hypermiling now and enrolling in autocross this summer.
Old 01-21-2013, 12:41 PM   #85 (permalink)
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
Good luck on the autocross, of all the types of racing I've tried, it was witbout a doubt the most fun.
Old 01-27-2013, 02:15 PM   #86 (permalink)
Sven7's Avatar
Ok, so I started re-building my grille block and mirror panels with pink sheet foam. It's much stiffer and less porous. Might have a mirror panel done soon. We'll see how it goes.
I want to take a picture of the salt deposits on the car for airflow reference, too. The top of the front wheel wells really needs to be capped off/gap filled.
Old 01-27-2013, 02:34 PM   #87 (permalink)
90 day: 51.82 mpg (US)
I gave up on expanding foam for the Insight too. I started on a grille block last spring and just ended up going back to duct tape and thin plastic. Foam board will be my next move for that part.
But I think I'm OK with the mirror part/expanding foam. It's been setting up since oh, around June. One of these months (years), I'll post it up.
Old 01-29-2013, 05:39 AM   #88 (permalink)
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
I have ebayed rear 'quick' struts on my corolla, ~20k miles on them, no problems. The auction was for monroes at a cheap price, and I would guess they were not monroe brand, just has the part number matching for monroe. I have some old (80s) shocks that are the same setup, monroe part number, but are another brand.
Old 01-29-2013, 03:17 PM   #89 (permalink)
Sven7's Avatar
Seeing if I can hook up a trade deal to get some new Ebay upper control arms aka camber kit. $100-$170 it looks like, while Skunk2 stuff is twice as much. Couldn't stand Tein's website so no word there. Worth the extra money?
Repainted the wheel covers "bronze metallic" and put them all on this time. The color looks either really awesome like a rally car or terrible like peanut butter.
Made a quick 'plast grille block that opens just for the radiator and began filing on the giant foam block. Working on the mirror delete panels but Bondo spotting putty eats foam really badly. I may end up spraying them with primer from a ways away- then it shouldn't eat away too much.
We got a lot of snow yesterday so when I got all the stuff on I took it out to a parking lot and drifted around a bit on the "closed course". Getting a better handle on the handling.
Look at the salt deposits. It needs the top of the wheel wells capped off... you can also see how badly the suspension is leaning.
Ren by Tyler Linner, on Flickr
Oh, and due to last week being well below zero, coupled with lots of extra-urban driving, this tank is not impressive.
Old 01-29-2013, 03:32 PM   #90 (permalink)
The peanutbutter hubcaps look pretty good from what I can see in the photos. Ever since I painted mine black, no one even notices them on the black car. Yours blends in well with the color scheme even though it is brown on red .
