Old 02-04-2010, 04:36 AM   #1 (permalink)
recession proof rebel
k.civic.f4i's Avatar
scangauge2 on a 92-95 civic
do you know if there's a way i can use a scangauge and still use the stock dx motor(d15b7 92-95)? maybe swap out a harness and ecu off of the 6th generation civics.
how to.....
http://ecomodder.com/forum/showthrea...cks-11998.html
http://ecomodder.com/forum/showthrea...how-12301.html
true wealth comes from good health and wise ways
Old 02-04-2010, 04:56 AM   #2 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
I'd say no but i've gotten used to thinking "never say never" here! My first reaction would be to get an mpguino. Much cheaper and FAR less hassle than changing out your wiring harness.
ollie
Old 02-04-2010, 07:05 AM   #3 (permalink)
Although there are advantages to having several data retrieval inputs when hypermiling, a simple vacuum gauge will give you most of the information you need to achieve great mileage.
Low RPM acceleration at 2 inches of vacuum is great for your pulse, then you want the highest vacuum when cruising. You can even tell when you are in a drafting situation with a decent vacuum gauge.
Rewiring a car so it would be OBD2 capable would be a monumental task.
regards
Mech
Old 02-04-2010, 08:37 AM   #4 (permalink)
Mater - '98 Dodge 3500 Dually
Wilber - '99 Toyota Corolla LX
Minyatta - '93 Mazda Miata MX-5
I was totally interested in the replies to this one!
Someone was selling a gauge for under 20 bucks, I missed that deal. Too many other home expenses at the time. #1, water was coming up in my basement.
I hate when that happens,
Dave
Old 02-04-2010, 04:59 PM   #5 (permalink)
vacuum gauge it is then. or mpguino.
how to.....
Old 02-05-2010, 08:15 AM   #6 (permalink)
Both work great! If you don't have a clock in your Civic, like I don't, You can install it, MPGuino, where the knock out is. The electric hook up for the clock is what you would use to power it. Almost looks like it belongs when finished. Just like your bumper block offs!
Or the vac gauge would install on the pillar & you could probably make the pillar mount for it!
Like I wrote both would do the job. What look do you want, mechanical or digital?
Dave
Old 02-16-2010, 09:53 PM   #7 (permalink)
The way I see it, it's pretty obvious man. I would probably set a mpguino (obviously to monitor your consumption).
95 Civic EX - Too much power abshnasko EcoModding Central 16 03-01-2011 11:19 AM
CNET: your '92 Civic may get far better MPG than a new car, but it still sucks! MetroMPG General Efficiency Discussion 48 06-23-2009 11:18 AM
New member, buying a 92 Civic DX, looking for opinions... exo General Efficiency Discussion 7 06-02-2009 02:06 PM
95 Civic VX Daox For Sale 8 04-17-2009 10:21 PM
Looking For Suggestions on my 95 civic hatch dx moonliver DIY / How-to 0 06-06-2008 02:10 PM
