07-31-2019, 10:32 PM
#21 (permalink)
Originally Posted by Taylor95
These look really good. Has anyone seen any problems with overheating brakes because of these coverings? Will this cause faster brake pad wear?
I had my brakes get hot twice with complete covers on all four wheels on my Civic on longer highway trips. I also used cruise control, so I surmise my brakes were being used more often than necessary. I removed the front wheel covers and never had anymore issues. Rear wheel covers were fine.
the Insight has almost completely smooth/covered alloy rims and has never had an issue with brake heat. It also doesn't have cruise control and I rarely use my brakes.
Efficient drivers drive as though they don't have brakes (braking kills MPG!), and mods will do no good unless you do the driver mod, so they should be fine unless you go racing around and braking everywhere, in which case mods aren't going to help your MPG at all..
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
The Following User Says Thank You to mpg_numbers_guy For This Useful Post:
08-01-2019, 10:50 AM
#22 (permalink)
Mechanical engineer
The Following 3 Users Say Thank You to Vekke For This Useful Post:
08-01-2019, 01:07 PM
#23 (permalink)
Cyborg ECU
Really gorgeous, Vekke. How did you make the second one? How is it secured from the back?
08-01-2019, 02:17 PM
#24 (permalink)
Originally Posted by jcp123
Oooooh, if I had a worthwhile pic host, I’d show you the nice new discs my company is using...
That's an odd thing to say considering:
https://ecomodder.com/forum/member-j...hondizzle.html
..Without freedom of speech we wouldn't know who all the idiots are. -- anonymous poster
..The quickest way to double your money is to fold it iin half and put it in your back pocket -- Will Rogers
08-01-2019, 02:26 PM
#25 (permalink)
Seems like that is a rare occurrence for most people with these covers. I'm still undecided of I want to do this on any of my vehicles. I'm thinking that performance rotors (the ones with holes) might mitigate the extra heat.
08-01-2019, 03:25 PM
#26 (permalink)
Mechanical engineer
First and second have 1mm thick aluminum plates that are just glued from behind.
08-01-2019, 05:39 PM
#27 (permalink)
I have to wonder if people doing the clear covers like them much after dirt builds up behind them. Seems like a PITA to deal with that would look like crap really fast.
2023 Kia EV6 GT
08-01-2019, 05:51 PM
#28 (permalink)
What do they look like after driving through a mud puddle? Snax covered it.
I'd have sworn I posted a Photoshop of a Moon disk with a half dozen radial louvers, but I can't find it now. I did find this while I was looking:
https://ecomodder.com/forum/showthre...tml#post503393
08-01-2019, 06:39 PM
#29 (permalink)
Moderator
I remember seeing that Mirai; it was at the Chicago Auto Show in 2016:
Modified pretty ridiculously, but the wheel covers were nice.
The Following User Says Thank You to Vman455 For This Useful Post:
08-01-2019, 08:18 PM
#30 (permalink)
If the outer half-silvered disk were convex wouldn't a fish-eye effect give a deep-dish look to a shallow offset? I confuse easily.
