Old 06-02-2012, 01:29 AM   #31 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I went with black for a few reasons--black was readily available, whereas factory matching color would have had to be ordered, and I thought it might look weird with the negative space of the stock grill and foglight hole covers turned red. I wasn't planning on extending the black that far out the sides, but I got carried away sanding. Plus, the black will match my eventual tail.
Originally Posted by Varn View Post
Nice job Vman. How do you see out your side mirrors. Seems like there may be some safety issues. When I had an Illinois drivers license I was required to have outside mirrors. It is a fairly common restriction.
Do you have narrow mirrors in your flattish panels?
Nope, just some interior convex mirrors from Autozone. I can see just as well as with the stock mirrors, and Illinois only requires one mirror(!), "so located as to reflect to the driver a view of the highway for a distance of at least 200 feet to the rear of such motor vehicle." So, blocking the rear window would make the interior mirrors no-go, but as it sits it's legal (but not in Washington, where it's registered until the tabs expire later this year).
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 06-02-2012, 01:55 AM   #32 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Subaru Legacy Wagon 2.5 GT
Subaru
90 day: 21.16 mpg (US)
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 53.91 mpg (US)
Olga - '03 Volkswagen Jetta Wagon
90 day: 46.24 mpg (US)
Very nice work! Thank you for sharing
Old 06-02-2012, 10:00 PM   #33 (permalink)
Deceptive - '98 Dodge Neon R/T
90 day: 44.38 mpg (US)
Looks good, did you do anything to the bumper to get the glass to adhere better? I almost did this back in 09, but the civic that did the foam/fiberglass bumper back then, he had problems with it cracking off of the bumper. The polyester resin doesnt stick to plastic very well. In the audio world, a lot of times, we'll drill a bunch of small holes through the plastic to get it to adhere better.
Old 06-06-2012, 01:54 PM   #34 (permalink)
Moderator
Vman455's Avatar
Actually, I used epoxy resin, which I understand has better adhesion properties than polyester resin to non-porous surfaces like plastics. I haven't had any problems so far (knock on wood).
The Following User Says Thank You to Vman455 For This Useful Post:
TOOSTUBBORN2FAIL (06-06-2012)
Old 06-06-2012, 02:05 PM   #35 (permalink)
You should be fine then, its rare people at home use epoxy resin. Not only should it adhere better, but its a little more flexible, so it should give a little more before breaking, in case anything hits it.
Old 07-02-2012, 06:01 PM   #36 (permalink)
Moderator
Vman455's Avatar
Well, I haven't had time to build my tail, and I'm leaving Wednesday for New Jersey. I did get coroplast full pans on the front and rear of the car (with aluminum under the downpipe and catalytic converter in front after the plastic started melting!) and a couple panels in the middle to cover up the center tunnel. I'm also experimenting with 6 vortex generators on the rear window, after tuft testing without them, with 10, and then removing 4--they're keeping the flow attached now, but if they're having an effect on fuel economy, it's not significant enough to tell. I may try and fab up a temporary coroplast-and-tape box cavity tomorrow if I have time....
aerohead (07-02-2012)
Old 07-02-2012, 08:27 PM   #37 (permalink)
3n3rgystar's Avatar
Silver Bullet - '92 Nissan Sentra XE
90 day: 37.59 mpg (US)
Looks slick, have a good trip!
Old 01-03-2013, 07:47 PM   #38 (permalink)
darcane's Avatar
Any pictures of the belly pan?
I'm considering it on my '01 Civic, but not sure if it's worth the hassle.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 01-03-2013, 08:09 PM   #39 (permalink)
Moderator
Vman455's Avatar
Once the weather warms up a little I can take some. I'm also planning on re-working the middle of the car with flat bar and more coroplast to make a smoother, full pan.
Old 01-03-2013, 08:10 PM   #40 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 27.11 mpg (US)
And done! After removing the flashing, I filled the grill and lower fascia opening with expanding foam:
Cut off the excess with a kitchen knife:
Then fiberglassed:
After our hottest weekend of the year last week (97--and it's only in the 50s today), I noticed my temperature creeping up when the AC was running. So I made the radiator inlet slightly larger than what I had in the sheet metal:
Sanding:
Lots of sanding:
Painted:
And on the car!
I adhered to the 10-foot rule; it looks pretty good...from 10 feet away. If I have more time in the future I can go back and clean up some spots, but overall I'm happy with it for how much time I put in. And it looks much less conspicuous than the galvanized steel!
Wow, looks nice, time to photoshop my xA to see how it would look like that
