07-02-2015, 07:59 AM
#21 (permalink)
Hydrogen > EV
Manual drive Mazda MP5. Plenty of space, decent mileage.
07-02-2015, 08:18 AM
#22 (permalink)
Cyborg ECU
I love those Metro pics, and I want to like the idea of a stretched Gen 1 Insight. But the added weight for what is already a low power engine makes me wonder. If the OEM car had merely been a 4 seater it would have had some difficulty with significant hill at speed if it had four passengers in it, I suspect. Since I imagine the stretched car woukd be for added freight and bedding... how would you overcome the low-power issue?
Maybe make the extension out of lightweight materials and make it as short as possible, dojng something clever to maximkze space?
James
07-02-2015, 04:45 PM
#24 (permalink)
Originally Posted by Frank Lee
How many engines have you converted to Miller Cycle?
I have messed more with Diesels, and getting a supercharger to use in a Miller is not so easy back here.
07-02-2015, 05:19 PM
#25 (permalink)
Master Novice
Guys,
With the original BMW turbodiesel and 5-speed manual (!?) the Vixen was supposed to be good for 30mpg.
It isn't as good as a Metro's mileage, but it is WAY better than sleeping in a tent and even better than some motel whose last bedbug eradication program was ineffective.
The Following User Says Thank You to elhigh For This Useful Post:
07-02-2015, 05:49 PM
#26 (permalink)
You made it sound like a guy could go out to the driveway after breakfast with a wrench and have it done by lunchtime.
07-02-2015, 06:32 PM
#27 (permalink)
B.O. Zen
Pickup - '99 Toyota Tacoma 2wd, Regular Cab, Short Bed 90 day: 34.62 mpg (US)
Originally Posted by rmay635703
That's pretty slick, but a bit steep at $100k.
Keeping in mind that this is all a thought experiment until there's actually a car chopped in half... stiffer springs should help w/ the weight. And it looks like DIY turbo setups can be done for a little more than $1k if one knows how to weld the tubes and whatnot. Bumping up to 100Hp would certainly help w/ the hill climbing and freeway merging, since it sounds like power's a concern w/ these cars. I think it's totally do-able. Soon as I move out of this apartment to a proper house with garage.  rotfl.
07-03-2015, 11:17 AM
#28 (permalink)
home of the odd vehicles
A leaf with front end damage + a leaf with rear end damage = $10k or less depending on how much you value the leftovers
Could even have 2 batteries if the rear ender wasn't hit too hard.
07-03-2015, 11:51 AM
#29 (permalink)
Not banned yet
getto - '02 Volkswagen Jetta GLS TDI 90 day: 53.82 mpg (US)
This from the same guy that doesn't blink when recommending people swap engines and design and fabricate their own engine management systems?  ........
I have always been more familiarized with engine swaps than structural mods and bodywork.
i've seen stretches on framed (how it's made) vehicles but never uni-body.
i think this was a question based on thoughts, not actually doing it. cost would be out of this enormous world and would require some unobtainium.
it seems to have turned into a pissing match though:
FOR SALE: 02 TDI Jetta- 5 sp: Cooper CS5 at 50 psi, UltraGauge, ventectomy, rear air shocks, mufflerectomy, LED plate light, upper fiberglass grille block, front lower pan, front fairing.
93 Chevy CrewCab 6.5 TurboDiesel, GearVendor OverDrive, 4L80 w/ TCI controls. Now DailyDriver
