Old 12-06-2010, 11:37 AM   #11 (permalink)
in tents
dennyt's Avatar
The Adventure Wagon - '94 Subaru Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '11 Surly Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
43mpg? That's crazy. I've thought of larger tires, but the lack of low-range is holding me back. 1st gear is barely low enough sometimes with a full car in the snow & getting to camp sites. Any ideas on 14" or 15" skinny rims with the 4x140 bolt pattern? Or maybe I could run some 155/80-15's on the temporary spare rims...
Old 12-06-2010, 11:46 AM   #12 (permalink)
on the loyal that i got 43 in-
it had peugot 14 inch alloys with 205 75 14s
on my 86 i used space save spares with 155 85s
the 92 got a clutch fan delete, intake thith cold air box, free flow exhaust, RX air damn and splitter, rear spolier and roof rack delete
removed a/c and all un needed weight
partial grill block
these numbers where observed traveling between ashland oregon and sacramento cali- not the flatest stretch of road- thi siskiyous killed.
but i traveled with cruise on at 58 or 60, for the whole trip, no stops
Old 12-06-2010, 11:47 AM   #13 (permalink)
also, low range was never needed, i plowed snow with the headlights a few times. it would have helped, but i accomplished what i was going after
Old 12-06-2010, 11:53 AM   #14 (permalink)
heres teh 43mpg car, and proof that i did mild offroading and expeditions with a single range trans
ID:	7489   Click image for larger version
Name:	SNOW 001 (2).jpg
Old 12-06-2010, 01:06 PM   #15 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Would pdx happen to be located in Maine? http://ecomodder.com/forum/showthrea...baru-9690.html
http://www.google.com/search?hl=en&q...er.com&num=100
Old 12-06-2010, 02:09 PM   #16 (permalink)
90 day: 29.78 mpg (US)
partial grill block
Amazing economy. I would think the pass would improve MPG on a manual trans. My Su always got the best when doing mountain climbing when I could coast down the back side. I averaged 28mpg in my Legacy, but would get 34 when spending a lot of time in the mountains.
You bring up good memories. I miss the girl...
Originally Posted by RobertSmalls View Post
Oregon pardner.
Old 12-06-2010, 03:06 PM   #17 (permalink)
portland oregon- not maine
im planning a 1200 mile trip[ this christmas and will report back
Old 12-06-2010, 04:42 PM   #18 (permalink)
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
If the larger tires helped significantly, that means the vehicle was over-geared greatly. Typically, the aero hit from larger tires and a lift would more than offset the gains from the taller gearing.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 12-06-2010, 05:38 PM   #19 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Welcome USMB guy! I havent posted there in a while.
I'd also recommend a grill block and LRR tires when season comes around again.
Old 12-06-2010, 08:35 PM   #20 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
silver fire - '03 Mazda Protege5
90 day: 32.52 mpg (US)
these are overgeared pretty high.
my 98 outback w/ manual was a steady 3300rpm at our hwy speeds of 70mph.
the engine in the OB (2.5L boxster) could easily handle much lower rpm.
~Mike
SUBARU AWD to two wheel drive gunrunner EcoModding Central 6 02-28-2012 11:26 PM
Subaru CVT vs 6-speed Manual bmwboarder General Efficiency Discussion 6 09-28-2010 01:07 PM
Subaru Justy Gear Swap? mtgeekman EcoModding Central 4 08-19-2009 11:33 PM
1987 subaru: hypermiler mode bgd73 Success Stories 0 07-24-2009 03:47 PM
Mpguino 98 subaru legacy Csht OpenGauge / MPGuino FE computer 0 11-16-2008 04:39 PM
