Old 11-21-2009, 10:40 PM   #1 (permalink)
Under belly pan
I'm considering using aircraft aluminum to make removable panels under the vehicle. What thickness do some of you recommend? Thanks!
Old 11-22-2009, 01:02 AM   #2 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I made an engine cover out of aluminum flashing that I riveted to aluminum bracing.
It rattled and made all sorts of weird noise when the car was at idle.
I went to a thicker aluminum ( about the thickness of a dime ) and that solved the problem, but the thing is surprisingly ....heavy !
I would suggest using coroplast. There are several members here that have used it successfully.
It weighs much less.
( And one more thing - coroplast doesn't have razor sharp edges either )
Old 11-22-2009, 03:20 AM   #3 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
Awww come on, sounds like a great anti theft device to me. Don't have to worry about anyone hiding under your car.
I folded the edges over and glued them on mine. Hardens the edge up a bit and keeps it from being razor sharp.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 11-22-2009, 12:44 PM   #4 (permalink)
Eco Dreamer
Versa - '08 Nissan Versa SL Hatchback
For something like a bellypan that requires a lot of cutting and fitting and contouring around uneven surfaces, etc. I agree that coroplast is probably the easiest way to go. Maybe just use aluminum right by the cat.
Old 11-22-2009, 03:59 PM   #5 (permalink)
Thanks CD! I assume that colorplast is cheaper than aluminum and easy to work with.
Old 11-22-2009, 05:07 PM   #6 (permalink)
CD - I Googled colorplast and found a company that makes it: there were 30 different materials available, not to mentioned thickness choice - yikes! Any recommendations?
Old 11-22-2009, 05:42 PM   #7 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Election signs. Or, the same stuff, as commonly available at lumberyards.
Old 11-22-2009, 08:04 PM   #8 (permalink)
Maroon Ballon - '98 Chrysler Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Geo Metro 5spd hatch, 3 cyl
I bought some Coroplast last week for about $13.60 per white 4x8x4mm sheet. Closer to $17 for colors. I first called a number of sign shops, because they use the material for signs, and I was hoping to recycle some old signs, but nobody had used stuff, so I asked them where they got their materials. A few different sign shops gave me some contact info on a few different suppliers, and the place I ended up buying from had a lot of different sheets of a lot of different materials, but they seemed to deal mostly in raw materials for sign makers. Look under signs and plastics. Good luck!
Old 11-22-2009, 08:18 PM   #9 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
I got mine from a sign shop, $30 for a 4 x 8 sheet.
Old 11-22-2009, 09:01 PM   #10 (permalink)
...beats walking...
...put strengthening "creases" in ALL flat panels (like airconditioning ducts have) to halt 'tin canning' due to turbulent air flow and mechanical vibrations.
The Following User Says Thank You to gone-ot For This Useful Post:
mcrews (11-22-2009)
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Aerodynamic Belly Pan on Toyota Echo jime57 Aerodynamics 23 12-05-2010 06:18 PM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 06:27 PM
Started on a belly pan brucey Aerodynamics 3 02-03-2009 08:14 AM
