Old 03-14-2012, 06:22 AM   #201 (permalink)
Audi - '97 Audi A6 1.9 TDI
I think factory seat weight also not su much 8-9 kg. Please weight it if you will have opportunity
Audi A6 TDi
VW Lupo 3L
Old 03-14-2012, 08:17 AM   #202 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Stock lupo 3l Front seat weights about 12.5 kg error tolerance is 0.5 kg.
Assistant front seat will be removed totally, and put only back when that is needed.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 03-14-2012, 10:26 AM   #203 (permalink)
Ok I look forward to see your results ;]
Audi A6 TDi
VW Lupo 3L
Old 03-14-2012, 04:10 PM   #204 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
My custom seat weigted 4.5 kg at the moment when std Sparco race seat was 7 kg. Carbonfiber wrc version is in the same range than my current seat. There will come also ventilation with electric fan to cool off the driver.
Oh and its not finished yet .
Two pics added to Facebook pages
https://www.facebook.com/photo.php?f...type=3&theater
Old 03-15-2012, 07:20 PM   #205 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
It doesn't look very comfortable, for only modest weight savings.
Replacing the body panels with plastics is where the major weight gains are, like with this Golf:
http://www.rohacell.com/sites/dc/Dow...nformation.pdf
Old 03-16-2012, 03:45 PM   #206 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Did you check also the picture with red paddings?
Its not as comfortable as OEM seat for sure but 5 times better than regular race seat.
Biggest problems with bucket seats are that your legs are tight together so your start to sweat easily.
In this seat I can move my legs and there is two electric fans to keep the air moving with adjustable speeds. after one month I will now how it will work in action.
I have previous experience from regular bucket seat from 5 years ago. In that 400 km long trip was too much for my back. Mainly due to leg issue.
To be able to remove 100 kg I have to change and modify pretty much everything I can because the factory has made the 3L body already 150 kg lighter...
Old 03-19-2012, 02:26 AM   #207 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Hi Vekke,
I've read your thread and I like it very much. Anyway I got this idea, that came to me while I was P&Ging. With the manual gearbox which is shifted by a robot, some logic and hacking & tweaking of the cuurent setup you may build an automated P&G system for your Lupo. With just 2-3 buttons to control it. You have everything that is needed. Start-stop feature, automatic gear shifting, automatic clutch. Just combine it together and voila!
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
Vekke (03-20-2012)
Old 03-19-2012, 07:06 PM   #208 (permalink)
ZX - '97 Citroen ZX Monaco
OldContinents
90 day: 61.05 mpg (US)
Originally Posted by Vekke View Post
Today started to make my boattail and the evo1 version is already tested that it wont fall off. Its manufactured from 3mm thick black abs and drilled straight to rear hatch. Length is about 600mm or 24"
Angles used on the side tried to get 10 degrees and the roof according to template C. When I try to fit it to the template it is quite close IMO :/.
How are legalities with such extended aerodynamic mods in our country?
I have had impression that extending outside of body lines would need reflectors at minimum, maybe even lights and still might be illegal, so I have limited my mods to bumper level?
Would like to get my next Kamm to extend further like this your photo shows.
Old 03-20-2012, 03:00 AM   #209 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Its illegal to make kammback any further than the body. Also its illegal to put any such things on your car which in newer than 1997. So any parts you put there are basicly illegal. In most cases police will understand, but you need to ready to pay some R&D costs made by police.
Good suggestion on the active P&G cruise control. If I would have skills to do it I propably would. You have few choices. Make mechanical system that pushes or pulls the standard gas pedal. That I could build easily. Make electrical verion which would fool the gas pedal positions to ECU. For that I dont have the skills.
But I think I will try to get some engineer to work on it as their graduation study/work .
The Following User Says Thank You to Vekke For This Useful Post:
jtbo (03-20-2012)
Old 03-20-2012, 05:19 AM   #210 (permalink)
OldContinents
Thanks from this, yet again one reason to dislike our car legislation system. I wonder if newer than 1997 includes 1997 too? Might need to get older specimen for aeromodding to avoid savings to go supporting our poor country
audi a2 3l 1.2 tdi, tuneko, vw lupo 3l.
