Old 03-08-2011, 05:02 PM   #11 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Waaaah, the food supply!
Seen any empty store shelves lately?
You mis-understand me. GMO corn and soy dominate farming. Consolidation like this makes the whole supply vulnerable to a single pest.
Old 03-08-2011, 08:00 PM   #12 (permalink)
...beats walking...
...re: Are we abusing alcohol?
...well, I can honestly say that I've never threatened nor struck a defenseless bottle of whiskey in my life!
...'cuz, all of them were 'armed & dangerous' as soon as their seals are broken (wink,wink)!
The Following User Says Thank You to gone-ot For This Useful Post:
Sularus (03-10-2011)
Old 03-08-2011, 09:05 PM   #13 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Abusing? No. Strictly for medicinal purposes.
Old 03-08-2011, 11:16 PM   #14 (permalink)
Ah. Well it was getting pretty consolidated anyway wasn't it?
Old 03-09-2011, 03:37 PM   #15 (permalink)
I don't think a parallel fuel system like proposed here has a mechanism for actually.. improving anything.
What I don't get is why the ethanol haters aren't mad at people with leather anything, wood floors, pieces of paper, shaving cream, diapers, glue, crayons, firecrackers, tires, or any of the other countless non-food things that use corn.
Work From Home mod has saved more fuel than everything else put together.
Old 03-09-2011, 05:37 PM   #16 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 144.39 mpg (US)
Send a message via MSN to jakobnev
You guys, this thread isn't supposed to be about politics!
Originally Posted by Ryland View Post
an engine that is designed for burning alcohol does not work well for burning gasoline and it's the same the other way around
Maybe you could point out some differences?
So you don't think that increased CR gives better efficiency for example?
Old 03-09-2011, 06:20 PM   #17 (permalink)
...beats walking...
...well, notable differences between gasoline and ethanol are:
gasoline (C8H16)... 115,400 BTU/gal; A/F = 14.7:1 ...%Oxygen = 0%
ethanol (C2H5(OH))...75,670 BTU/gal; A/F = _9.0:1 ...%Oxygen = ~35%
...and, thus, ethanol has only 70% energy density of gasoline.
...and, E85 content is 15% gasoline and 85% ethanol.
Old 03-09-2011, 06:34 PM   #18 (permalink)
Eco-ventor
jakobnev's Avatar
House of Tudor
Team Mazda
Plug-in Hybrids
ethanol (C2H5(OH))...75,670 BTU/gal; A/F = 9.0:1 ...%Oxygen = ~35%
I was trying to ask him how the engines would be different. (Besides obvious things like AF-ratios.)
Old 03-09-2011, 07:45 PM   #19 (permalink)
Ethanol resistant materials for the fuel system. Carb'd will be jetted bigger and injected may have bigger injectors. Dedicated ethanol engines have higher compression ratios; flex-fuel engines are saddled with the lower gasoline C.R.s which compromise efficiency when they're running ethanol.
Old 03-09-2011, 08:40 PM   #20 (permalink)
Compression ratio is the big thing mechanically wize, turbo's are the make shift compromise, E85 with the higher octane rating won't dentonate nearly as easy allowing for either higher compression ratio or higher boost pressures. Saab has been making the best E85 cars for 5-6 years, the timing, boost pressure and more vary depending on fuel. They make more HP & torque with E85 than regular. One article by Saab I found a few days ago, but can't again said they expect 15% better hwy FE, same city or combined.
In 2007 someone else did some testing of Saab's FFV car, HP numbers agreed with Saab, FE didn't in standardized testing, it was the normal roughly 20% less (almost same as my wife 02 Suburban that does 12.5 on E85 vs 15 E10 on her 4 mile commute, 83% of E10's mpg). Compared to an 2010 or 2011 Malibu's 33 hwy E0 vs 23 E85's is 69% of E0).
Energy density is one thing, higher compression I think increases efficiency so a engine capable of running higher compression can be more efficent. I want to see a E85 engine that can run E0 when neccessary.
