View Poll Results: which should I use
small hinge (picture A) 9 75.00%
bracket (picture B) 0 0%
somthing else 3 25.00%
Voters: 12. You may not vote on this poll
Old 08-09-2010, 02:05 PM   #1 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
wheel skirt attachment poll
which should I use to attach my wheel skirts to the top of the wheel well?
A: small hinge
B: angel bracket
C: something else (please note)
Old 08-09-2010, 03:25 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Weather Spotter -
I voted A because I like that version of the mod. I would keep strong (hard disk?) magnets in the trunk for use in holding the skirt up when you are servicing the wheels.
CarloSW2
American Solar Energy Society
Old 08-09-2010, 04:42 PM   #3 (permalink)
In my experiment with full coverage skirts I discovered the importance of being easily able to access the tire air stems. I would like hinged skirts better than removeable ones.
Old 08-09-2010, 07:27 PM   #4 (permalink)
Lil Sulf - '94 Toyota Corolla
90 day: 47.62 mpg (US)
Large hinge?
Is that tiny thing strong enough to keep it attached if the wind gets under it or something?
And that's without a Scangauge o.O
Old 08-09-2010, 07:50 PM   #5 (permalink)
In the winter I have to go to the coin op car wash and water jet the snow out of the fender wells or it will start rubbing on the tires. That restricts turning and kills FE. The hinge would definitely be a must have if it is strong enough.
Old 08-09-2010, 07:52 PM   #6 (permalink)
Wiki Mod
Originally Posted by Sulfuric View Post
Large hinge?
We will see, I think that if I go any bigger it will not sit flush. I attached it to the car with 2 sheet metal screws.
Old 08-09-2010, 07:56 PM   #7 (permalink)
Wiki Mod
The last few winters when I stop I kick the build up with my boots and it falls out nicely. I will have to see how this works, I may have to mod/ remove it when there is lots of snow (or slush which is worse).
Old 08-09-2010, 11:20 PM   #8 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
You'll have to shim between the hinge and the fender so the curved part of the fender becomes flat fer the entire hinge.
Old 08-10-2010, 02:47 AM   #9 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I'm all for hinges.
My skirts are mounted with 6 (!) screws each, which I know is overkill, but with less the car's other users wouldn't think it's safe. When these need replacing I'll use less screws and hopefully a hinge, since starting the engine just to have access to the tire valve is a PITA.
Last winter I had no problems with snow/ice, only with salt that ruined the skirts' paintjob.
Old 08-10-2010, 07:22 AM   #10 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
So don't start it - just push a little!
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Rear Wheel Skirt using water heater drain pan cfg83 Aerodynamics 45 02-20-2012 02:08 AM
2000 Mazda Protege Rear Wheel skirts Walk Through Blue Bomber Man Aerodynamics 13 08-29-2009 02:12 AM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
Dream Wheel Skirt. Am I Crazy? 2003protege Aerodynamics 7 05-21-2008 01:40 PM
