Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 07-24-2011, 04:11 PM   #21 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
CNG is cheaper to use but the start up cost is high and its difficult to store a lot of CNG on a car or truck.
I wouldn't mind running propane again but I think my compression ratio with turbo is too high, if I did use propane I would only be able to use it in say the 2-6 psi of boost range.
I have considered running water methanol at lower boost.
I think I would be better off running water methanol since it would enhance the temperature differential between both the hot and cold reservoirs. The evaporation of the water methanol makes part of the cold reservoir cooler, then when the diesel is injected and lights off the methanol, both burn off and help make the hot side hotter.
Actually, your compression ratio is fine with boost. Go over to Heath Diesel's site and see what they are doing. Try 30 psi boost on top of 22.5 to 1 compression, water-meth injection, twin turbos, NO INTERCOOLER. All on a 6.2/6.5 based engine.
The race truck gets 30 mpg on the highway. Does over 160 mph. Stock cam, heads, intake manifold, etc. Good stuff.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
Old 07-24-2011, 06:22 PM   #22 (permalink)
I just buy products from heath, never read his stuff.
Looks like I am about to start.
I have herd heath likes to fill there high power blocks with block filler up to the bottom of the water pump inlet holes. I thought about adding some block filler (since I did build the engine up from a bare block in my living room) but didn't want to add another 30-50lb of weight to the engine. I would rather have 30-50lb more load capacity or get up a mountian that much sooner.
I have herd the 6.5T doesn't do well on water methanol. Only thing I can think of is there timing could be too far advanced on a stock engine. Heaths 2bar blown diesel could be running less timing than a normal engine.
Old 07-24-2011, 06:29 PM   #23 (permalink)
True on the block fill, and the engines don't run hot at all. The pump that he uses is an off the shelf Stanadyne DS4, and they use their software upgrade with a higher rpm limit, nothing that a customer can't purchase themselves.
The engine can handle water/meth just fine.
There's an article in Diesel Power about the LSR truck that Heath built.
Like I said, good stuff.
Old 07-25-2011, 01:44 PM   #24 (permalink)
I looked up the diesel power article on heath, they said he was running pure water, to the tune of 1 gallon of water for every half gallon of fuel burned.
I will be using the 6.5 turbo block with 6.2L heads and fuel system. I wont have any of that PMD nonsence.
Also I have no problem sticking well below the 4,400rpm limit mechanicly built into my DB2 injector pump.
Old 07-25-2011, 11:37 PM   #25 (permalink)
Originally Posted by deathtrain View Post
real men use ether
At least, that's what Hunter S. Thompson told us in "Fear and Loathing in Las Vegas".
-soD
Old 07-26-2011, 05:18 AM   #26 (permalink)
...beats walking...
real men use ether
...those here with 'warped' senses of humor (like me) will appreciate the LOLs I emitted when I mistakenly read those words as: "...real men use either.."
Old 08-01-2011, 06:30 PM   #27 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
New CNG tank setup in truck - Diesel Place : Chevrolet and GMC Diesel Truck Forums
http://www.mrsharkey.com/lpg.htm
I thought every one that was a diesel modder knew of propane/natural gas fumigation.
It is very unfortunate that I cannot buy a decent adsorbed NG tank here in the US, they use them on mopeds in foreign countries but won't sell them here except for low volume torch applications.
An adsorbed tank would eliminate the need for a $3k pump every year and eliminate the high cost of NG cars.
Old 08-01-2011, 07:12 PM   #28 (permalink)
Absorbed gas? like the way you dissolve Acetylene into acetone for storage and transport?
Old 08-01-2011, 07:18 PM   #29 (permalink)
rmay635703's Avatar
Not exactly, NG will "pressurize" at low pressures in the presence of large amounts of activated charcoal.
Adsorbed Natural Gas Technology
G-TEC Adsorbed Natural Gas Cylinders
Old 08-01-2011, 07:25 PM   #30 (permalink)
Sounds simple enough, gas cylinder + active charchol + mild compressor.
Any idea what the start up on this is?
With the "american way" its $100s of dollars for the tanks and the high pressure boost compressors run about $3,600 (last time I looked).
