Old 06-13-2017, 04:51 PM   #61 (permalink)
Focused on MPG
Marinator - '06 Mercury Mariner Premier
90 day: 15.45 mpg (US)
SILVER BULLET - '19 DODGE GRAND CARAVAN GT
90 day: 19.65 mpg (US)
Myrtle - Wife's JKU - '12 Jeep JK Unlimited Sport
90 day: 15.99 mpg (US)
Like to eat huh, want a passenger....I would even pay for gas, cause I like to eat burgers, and definately cake!!!!
Well crap, my wife said no to the trip and that I need more "health food"...lol
Staying Focus'd on MPG
Old 06-13-2017, 11:42 PM   #62 (permalink)
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
Originally Posted by BabyDiesel View Post
I've been turning the key off to EOC. It is annoying, especially since the Insight's engine takes several seconds to die and I can't turn the key back to ON right away. Gaining over 10 mpg in town is worth it.
I have your chip on my wish list actually Money has been tight, hopefully I can place an order soon.
This is the clutch switch mod, correct? I've read about it numerous times on InsightCentral and is on the to-do list as well (I have a ton of things I want to do with my Insight lol). I'm definitely interested, so give me as much Insight into this mod as you can
Yup, so two mods here.
Mod 1: Clutch Switch
These photos are from my old Silver G1, but my new Red G1 has the same electrical setup. Anyway, you can see on the left in an accessory slot I have a black button and a red LED. The clutch, if you follow the pedal up to where it's bolted into the firewall, up there you will see an electrical connector leading to it with two wires. When the clutch is depressed a button inside there is pressed which closes the circuit between the two wires. If you run two more wires to your own switch you can press your new switch to close the circuit and trick the car into thinking the clutch is depressed.
If the car thinks the clutch is depressed it will in most scenarios (99% of the time) not provide assist or regen. The way I wired it was I put a 68 ohm resistor and an LED in series with the black button so when the button is pressed in the LED lights up so that I know the switch is on. This is a SPST Maintaining button, you don't want a momentary button.
Mod 2: EFAS chip and a DPDT relay
This photo also from the Silver G1, but I did the same in my red Insight. This is a SPST Momentary pushbutton switch on my shifter. It goes to a relay I hid under the cupholders:
This photo is from the Red G1 but the board was exactly the same on the Silver G1. The black relay is a DPDT relay that gets activated when you press the button on the shifter. On the right side it switches the VSS signal being given to the ECM to be the fake one generated by the Arduino clone you see at the top of the board. On the left side the yellow wires lead to one of the wires from the clutch switch. When that relay gets activated it breaks the circuit of the clutch switch, turning it off, which makes the car think the clutch is not being pressed (unless you were also holding the actual clutch down).
So with this combination, once you got it setup, what you do is you disconnect the 12v battery for 10 seconds, and then hop in the car and turn it on and turn on the clutch switch. And leave it on. The car will drive like crap for the first 5-10 minutes, and attempt an IMA battery recalibration. But once it's done that it will drive normally and there won't be an IMA light.
Except it won't try to assist you or regen ever, so the car will never figure out that the IMA is deteriorated. Because it has no idea the IMA is bad, now you can use Auto-Stop either normally or with my button, and you also can get Lean Burn. Furthermore, using my button for Auto-Stop is superior to injector kill or key-off because the car will go back into Lean Burn faster (10 second delay with the other methods) and you never get the stupid dash lights and the EPS stays on the whole time.
I have a thread regarding the Auto-Stop button and how I developed it here or you can post in my red car's build thread about it if you don't want me spamming up this one.
The Following 5 Users Say Thank You to Natalya For This Useful Post:
BabyDiesel (06-16-2017), Daox (06-14-2017), Ecky (06-17-2017), ECO-AKJ (06-14-2017), roflwaffle (06-17-2017)
Old 06-16-2017, 06:25 PM   #63 (permalink)
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
Thank you Natalya! I don't care if you spam my thread with your information. The more places it is posted, the greater chances of someone else who needs the info finding it
I'm about to leave on my trip to NC! I'm looking to drive there on 1 tank of fuel. It is 974 miles and I will have to average 92+ mpg to make it without running dry. I'm optimistic, but reality says this probably won't happen without lean burn. We will see!
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
Old 06-17-2017, 08:43 AM   #64 (permalink)
Focused on MPG
Safe travels and Happy Hypermiling! !!
Old 06-17-2017, 10:14 AM   #65 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Get a one gallon gas can and fill it for the trip. Then you can push to your last drop in the tank without fear of getting stranded.
Old 06-20-2017, 09:42 AM   #66 (permalink)
Lean Burn Cruiser!
BabyDiesel's Avatar
Gen-1 Insights
House of Tudor
Team Streamliner
Thank you FordMan for the well wishes! Funny thing is 98, I had one at the house. It was stolen along with my weedeater a few days before I left!
I made it to NC Saturday afternoon, safely but barely. I had been up for 36 hours at the end of the drive. To make it worse, I hypermiled a 14 hour trip and turned it into 20 hours. I was beginning to hallucinate along the last leg of the trip, seeing shadow people and things along the side of the road moving. It wasn't the best situation but I toughed it out.
I managed 85.4 mpg from West Plains to Lumberton 914.7 miles on just over 10.7 gallons. I hate that I missed my kilotank! As I suspected, not having lean burn was a deciding factor, along with night driving, the Arkansas mountains and Lower Appalachian mountains in Georgia and so many hills elsewhere.
Natalya, I understand why you can't get better mpgs now. Atlanta was about the most brutal part of my drive! The traffic and insane drivers, just wow...
Since being in NC, my prediction on the mpgs I would see out here were spot on. I'm getting low to upper 80s, sometimes into the 90s driving the same routes as I did in my Escort! I achieved 99.6 mpg on an 8.7 mile cold start morning trip to McDonald's yesterday morning. This area was made for the Honda Insight, for sure
Past threads:
ZX2 modding thread
Old 06-20-2017, 10:42 AM   #67 (permalink)
I've heard that the Honda Insight can be driven even if the battery pack is damaged or completely dead. Is this true, and why didn't Toyota do the same with the Prius?
That's why I never got a Prius, they are basically a throw away car. I would've gotten one if I didn't know I would HAVE to spend $4k-$5k in 10 years on the battery crap.
https://youtu.be/kOn6ZW7x2kg
Old 06-21-2017, 04:56 PM   #68 (permalink)
Focused on MPG
Glad you made it safe, and you are still double the mileage I am!
Old 05-07-2019, 08:14 PM   #69 (permalink)
Lean Burn Cruiser!
BabyDiesel's Avatar
Gen-1 Insights
House of Tudor
Team Streamliner
Hey everyone, I'm still alive!
There is so much to catch up on... life has been full of ups and downs with more downs than ups. That is what life is tho, and I am taking it in stride.
I moved back to NC last year to be closer with my family. I still have the '00 Honda Insight! It is still pumping out 60 mpg on the regular. Less if I desire, and definitely more if I choose to flex my skills
I can say that a 27 mpg tank is possible for an Insight!
How is everyone else doing???
Past threads:
ZX2 modding thread
Old 05-07-2019, 08:20 PM   #70 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 53.2 mpg (US)
Welcome back. There is some cool Insight stuff going on here. Check out Ecky’s un-ecomodding thread.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
